Home > Maintenance & Modifications > Bulb Replacement and the Manual
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
hmm nearside low beam had gone, if i had followed the manual, the front grill had to come off, then the complete light assembly, then the cover and then finally out with the bulb... Bull5h1t.. You can just unscrew the cover, twist the holder anti-clockwise and voila, the bulb is there for the changing.. Not so easy i grant you on the other bulbs..
Did they write the manual prior to vehicle assembly Laughing Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #196396 Sun Nov 16 2008 8:08am
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
It really depends on what engine you have under the bonnet Zilch. On the TDV6 you have a fair amount of access to the rear of the headlamp unit. On something like a 4.2 litre s/c its not so easy. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #196404 Sun Nov 16 2008 9:37am
Zilch
Good point TB.. perhaps an insert for TDv6 owners like moi
"For the greater unwashed, without butler and white gloves you may be able to access the bulbs directly" Wink Another Pommie Bar Steward down under
Post #196411 Sun Nov 16 2008 10:26am
TB
I agree with you there.
The first time I ventured into Europe with my motor, I read the manual and started ripping the front of the motor apart so that I could swap the headlamp beams over to the european setting. It was only after removing the one headlamp and flipping the switch over inside the headlamp unit, that I realised I could do this from inside the engine compartment. Confused
So a potentially damaging 30 min process was quickly reduced to a 2 min process for future trips. Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #196412 Sun Nov 16 2008 10:53am
