Home > General > Right or wrong tyres?
Michael997
I have just bought what I hope was a bargain but maybe someone out there knows different.
I have just bought a set of 4 new alloy wheels fitted with new tyres for £660.00 to put on my RRS HSE only problem is the new tyres are a different size to my existing ones.
The new tyres are 255/55 R19 111V
My existing tyres fitted at 24k now 45k are 255/50 ZR19 107 Y
So my burning question can I still fit them and what problems may I encounter, the new ones also look larger.
Michael Michael
2013 RRS diesel Autobiography Dynamic
Post #181004 Fri Aug 01 2008 8:25pm
You should have had 55's before - 55's are what you need. 2005 Zambezi TDV6 - Gone but not forgotten
Post #181006 Fri Aug 01 2008 8:38pm
EX-X5!
Could be wrong here, but I always thought that the profile (depth) of the tyre is reduced generally speaking as you go up in rim size to ensure the rolling circumference is the same - this means the speedo wont be out? Is this right? Question
Post #181042 Sat Aug 02 2008 7:55am
Michael997
Thanks Guy's
So what sizes are on YOUR HSE's
Michael Question Michael
Post #181043 Sat Aug 02 2008 8:00am
EX-X5!
Well ive got 20" stormers on - I think they are 45 or 50's - not sure and i'm not going outside to check cos it's raining Big Cry Big Cry Big Cry
Post #181044 Sat Aug 02 2008 8:09am
Michael997
Wimp Rolling Eyes Smile Michael
Post #181052 Sat Aug 02 2008 9:15am
My tyres are 255/55 19 - I was presuming you are on 19's from the picture on your avatar. 2005 Zambezi TDV6 - Gone but not forgotten
Post #181060 Sat Aug 02 2008 10:33am
Standard size on RRS 20" are 275/40R 20.
FFRR has 255/50R 20 presumably for better ride comfort Thumbs Up Runner up - 2009 Best Avatar Award Sad
Post #181064 Sat Aug 02 2008 11:22am
Leo
Kenya
The standard size is 255/50/19, however, 255/55/19 is perfectly ok. The G4 RRS have Goodyear MTRs that come in 255/55/19 so LR see nothing wrong with it. In fact, you'll have a smoother ride.
Post #181069 Sat Aug 02 2008 2:46pm
Michael997
Thanks Guy's
I put them on yesterday and all drives ok.
I am still concerned that in my handbook it does not list 255/55/19 also mine are V rated and the ones I took off are Y rated.
Confused
Michael Michael
Post #181084 Sun Aug 03 2008 7:31am
Olduser2
My understanding is that you took off tyres which have a higher speed rating than your replacements (i.e you took off Y Rated = 186mph and replaced with V Rated = 149mph.
Post #181085 Sun Aug 03 2008 7:51am
Michael997
Thats right Tumshie
M Michael
Post #181086 Sun Aug 03 2008 8:17am
John @ DW
The profile number is the height of the side wall as a percentage of the width so the 255/55/19 will be bigger than the 255/50/19. By running a larger diameter tyre you will put your speedo out, acutally your speedo will be 3.5% out so when your speedo reads 60mph you will actually be doing 62.1mph. Apart from that running the 255/55/19 should not be a problem. Your new tyres have a higher load rating, so you are ok there and tumshie is right about the speed rating so you will be safe to 149mph. www.designerwheels.co.uk
Single piece, 2 piece and 3 piece alloy wheel specialist
17"-26", subltle or bling we have it all
Post #181285 Mon Aug 04 2008 9:19pm
