Home > Technical > Rear Brake whine... |
bt11 Member Since: 02 Mar 2008 Location: North west Posts: 95 |
So this is the 3rd time I’ve had my TDV8 in now for a really annoying whine when i set off... seems to be coming from the rear drivers side wheel!
Fri May 30 2008 12:03pm |
All sorted... on closer inspection seems the sping on the caliper wasn't aligned or functioning correctly so this was causing the noise.
Fri May 30 2008 2:38pm |
