![]() | Home > Technical > 08 Range Rover sport North America Navigation on the go code |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 ![]() ![]() |
I thought 08 models came pre-unlocked??? No ? |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
in the UK it was unlocked even for 07MY however clearly different for the US |
In the US, satnav on the move wasn't ever introduced, but they also removed the ability to use the unlock code. Umberto has often mentioned this... |
NYCsport Member Since: 26 Jan 2007 Location: New York Posts: 16 ![]() ![]() ![]() |
On U.S. models, 1791 works only on the 2006. There is no known hack of 2007 and 2008. Maybe Tata is less afraid of litigation than Ford. |
Passatglx Member Since: 28 May 2008 Location: Mahwah Posts: 12 ![]() ![]() ![]() |
Ist not ford or tata. Its denso who has the codes. Hopefully somone will come up with the code. Until then ![]() |
what exactly would I be asking for if I enquired?
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
"Gimme the f*cking code, you mothaf...!". Can you do a heavy Southern Italian accent? Leave the gun, take the cannoli. ![]() ![]() |
Kaine, Denso makes the nav units for jag/landrover. They have codes to unlock the " Nav on the go" They kept these locked for the US market. They are the only ones who hold the code. This code will enable us to drive use nav features that are locked out once you go past 5 mph |
FWIW, a few months ago I spent some "quality time" examining the dreaded loading.kwi file in both 2006/7 and 2007/8 North America DVDs, with a plain vanilla text editor on my computer. This is the file that contains all of the "secret codes" used by Denso in our navigation software to access diagnostics and so on. Although the majority of the file is obviously unreadable gibberish when using an ASCII editor such as my PC's Notepad (I don't have a kwik file editor), certain areas of the file are readable text, and these few areas do contain the sequence of codes that do - or did - something in the satnav: 753, 134679 - these two access diagnostics and have been documented in the past - and 1791, which used to enable on-the-go navigation in 2006s. I scoured around these areas but could not find any other codes that would do anything at all.
xLusi0n Member Since: 12 Jun 2007 Location: Los Angeles Posts: 92 ![]() |
Maybe someone will hack it all together |
I know DENSO make the units (I used to work for DENSO for many years for my sins) - my question is what exactly would I ask my contacts for? Will they understand me when I ask for 'the code that makes NAV on the go possible' - normally they will relate more to technical terms |
DENSO US wont have access to the dept in DNJP regarding the SatNav development - the departments in DNJP (DENSO Japan) are huge and you need to be in the division to get info. The Nav system was developed between DNJP and DSUK (Denso Sales UK Engineering) in Coventry - only guys from these two departments would have any info on this - I'll ask |
![]() ![]() ![]() interestingly that technique did used to work - the other way to get info was to talk about the War and the Japs would help you out no end ![]() |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2589 ![]() ![]() ![]() |
I have the same touch screen sat nav in my FFRR, how do I gain access to the 1791 bit so I can enable mine?
