![]() | Home > General > Advice re air suspension |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
I was going to say it could be an air leak on the air spring, but if you have been driving it just before hand, it's more likely to be the height sensor is not calibrated correctly.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Mine does this sometimes. No issues, it’s just doing the automotive equivalent of adjusting its underwear. But I understand if you want to be safe rather than sorry given warranty expiration.
It's just levelling itself up. Perfectly normal.
Same as Kev. |
1stRangie Member Since: 21 May 2019 Location: Dumfries Posts: 13 ![]() ![]() ![]() |
If you read the info on the air suspension it’s quite an eye opener. I can’t remember the exact detail but the suspension ECU monitors the suspension after ignition off every hour for a period and re-adjusts to level. 2019 5.0 SC SVA (Current)
One reason why you should lower to access height before switching off the car - the system then goes in sleep mode after a while shutting down all the systems saving battery drain. If you leave the car at normal height the system thinks you will be coming back to the car soon and stays awake, ready for a quicker get away. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
Is there really documentated evidence of this Tim ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5092 ![]() ![]() ![]() |
It does this amongst other things, but guess if in access mode would not do it as already at its lowest. Always thought when car locked after a few minutes the whole car went to sleep.
Tell you what, when I adjust my underwear, accompanied by the sound of escaping air from my front or rear, I don't half get a b*ll*cking for some reason 😁 |
