Home > General > MOT today
GodivaNige
MOT today
I hate MOT day. Rolling Eyes
In about 3 hours time, I’ll either be stupid happy or morbidly depressed... tick tock, tick tock
Rolling with laughter or Big Cry
Post #551417 Thu Mar 15 2018 6:29am
Eaters
It'll be fine! What could possibly go wrong? Its a TDV8 after all Laughing Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #551420 Thu Mar 15 2018 8:00am
GodivaNige
No advisories, sweet Thumbs Up
Post #551432 Thu Mar 15 2018 10:35am
Eaters
What a beauty - I had every confidence as mine had an MOT last week and sailed through without any problems. I had just had two new rear shocks fitted the week before though.... Shocked Robin
Gone:
MGZTT 190 2.5
Post #551437 Thu Mar 15 2018 11:39am
d-9
Shocks fitted inside the airbags? I assumed they came as a complete unit. Did they make much difference?
Post #551443 Thu Mar 15 2018 12:34pm
kismet110
I dread the MOT too, you just never know what will be thrown up.
Last month was mine and it wasn't too bad; crack in one alloy, power steering universal joint, 2 bulbs and seat belt tension not correct on front passenger seat - latter 2 were simple fixes and former two not stupidly expensive.
Some advisories but none of them serious so not going to lose sleep over them!
Post #551479 Thu Mar 15 2018 5:13pm
Cymruambyth
Wales
Thumbs Up Steve.
Post #551491 Thu Mar 15 2018 6:05pm
Eaters
They made a significant difference! I hadn't noticed as it was a gradual reduction in performance but the offside one was pretty bad. I had noticed that when breaking from high speed on say leaving a motorway, there seemed to be a bit of a twitch through the steering. It was not obvious what was causing it or even if it was actually there at all. I put it down to uneven road surface. However, with the new shocks on the problem has gone away and the car feels much steadier.
If you want to check yours, what I did was open the tailgate and get into the boot then bounce on the rear end. The car should go down, up and then return to the start position. If it oscillates more than that (i.e. bounces up and down twice or more) then you should get your shocks properly checked. The difference is considerable and now looking back I feel that the car was quite dangerous in it pre-fixed condition. Robin
Gone:
MGZTT 190 2.5
Post #551553 Fri Mar 16 2018 8:15am
d-9
Thanks Eaters, thats useful advice. I usually regard dampers as a service item and find they need replacing at about 120k. Can you replace just the damper, or do you have to replace the whole strut with the airbag like these:
https://www.johncraddockltd.co.uk/land-rov...sport.html
Post #551579 Fri Mar 16 2018 12:57pm
You can replace the damper or the whole strut. Whole strut needs to come out to change the damper and then there's the time to swap the dampers out. The whole strut isn't much more than the damper alone so probably little in it on cost. 2012 SDV6 - it's missing a couple of cylinders
Post #551583 Fri Mar 16 2018 1:14pm
Eaters
Not sure but my invoice only talks about rear dampers (part number LR016420 if that helps). Cost was £350 plus labour. Robin
Gone:
MGZTT 190 2.5
Post #551599 Fri Mar 16 2018 2:48pm
