Home > Technical > Replace or charge Battery
Richchad
If you are concerned at all and are anywhere near Abingdon pop round and I will do it for you FOC Laughing Thumbs Up
Post #475061 Fri Oct 02 2015 4:33pm
Richchad
Col, that is very kind of you, I am only in Wheatley.
I will have to get the battery first, maybe next week, but it doesn't look that difficult really.
Just wanted to get everything clear before I attempted it.
I will see how it goes when I get the battery, thanks for your offer, will update on here how it goes.
Regards
Richchad https://www.plus.net/refer.php?strReferral...d093cba6a7
Gone - RRSPORT TDV6 HSE
Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course.
Post #475063 Fri Oct 02 2015 4:44pm
Lost for Words
Richchad wrote:
Thanks Lost for Words, so disconnect Neg first, then Positive, wrap pos lead in cloth as someone on here suggested to prevent it touching any metalwork.
Remove battery, fit new one, connect Positive first? then Neg...
Yes, that's fine. When not removing the battery, plastic bottle caps can be useful to put over the terminals. Wink
Quote:
Someone on here also said that all that was need on reconnect is to reset date & clock?
Yes; thankfully, no radio codes. ISTR the navigation country may need resetting too. Thumbs Up Visiting from DISCO3.CO.UK
Post #475122 Sat Oct 03 2015 9:24am
Richchad
Okay, battery arrrived this morning from Tayna, discount code worked, thanks Lost for Words.
Fitted battery this afternoon, all went smoothly, reconnected and reset date & clock.
Started okay, everything looks like it should, haven't taken it for a run yet, hopefully all will be okay now.
Thanks again Col for your offer. https://www.plus.net/refer.php?strReferral...d093cba6a7
Post #475482 Tue Oct 06 2015 2:34pm
