Home > Technical > suspension venting not decreasing
Mitchmx
jumped into the car this morning and...........DING!!! suspension fault.. Censored Censored F**king thing! gurrrr
plugged it in and it come up with pressure not decreasing through gallery.
which pipe is it on the compressor that blocks up? someone did say a while ago that putting a air line down the venting pipe will unblock it but just wanted to find out which one befour i put 160psi down the wrong pipe.
thanks for any help Wink
Post #369427 Tue Jan 15 2013 11:21am
Disco_Mikey
On an 06MY, it is probably a wiring issue in the N/S/F wheelarch. IIRC, it is a Blue/black wire that corrodes and causes the same issue as yours
Post #371021 Sat Jan 26 2013 10:09am
Mitchmx
Thanks for the reply. Is it easy to find? Gonna have a go at it today. It's winding me up everyday!! 😡
Post #371025 Sat Jan 26 2013 10:59am
Mitchmx
Well I think I found the wire in question but it looks ok.
Looks like someone's been in the before aswell. There was a repair to another wire there but that looks ok as well.
So I thought I would check out the compressor but it looks like its been changes recently.
I've fitted a new rear o/s height sensor aswell but the computer still says that its faulty? Wires look ok and not corroded.
Big Cry
Post #371033 Sat Jan 26 2013 12:50pm
Mitchmx
http://s9.postimage.org/akjwqigsv/image.jpg
Here's the blue black wire
What is this wire tho. Just found it floating about?
http://s13.postimage.org/lmh6jiqd3/image.jpg
Anybody help?
Post #371062 Sat Jan 26 2013 9:48pm
