Home > Technical > Sirius Radio
USAGivGrn
United States 2006 Range Rover Sport 4.4 V8 HSE Giverney Green
Sirius Radio
I've had my new RRS into the dealer for a radio/antenna replacement, but it still has a failure of the Sirius Radio whenever the temperature drops below 40 degrees F. It'll start working again if you park it in a heated garage for a while. Any ideas other than moving to a more favorable climate?
Post #8608 Thu Dec 22 2005 2:56pm
thebishman
United States 2006 Range Rover Sport Supercharged Bonatti Grey
My Sirius comes in great at recent temps of 0 F. Very quick 'lock' after backing out of the garage, and no 'drop-outs'. You must still have a defective antenna or some other connection needs attn.
Bish '06 RRS S/C Bonatti Grey/Ebony/Cherry with RSE; PTI; Electronic Rear Diff and Sirius Sat Radio.
Post #8691 Thu Dec 22 2005 9:48pm
grommet
United States
What did they really fix or replace? Are you sure they really did something? Smile
Post #8697 Thu Dec 22 2005 10:59pm
USAGivGrn
Well, I am not sure they replaced anything but they kept it two weeks and said they did. I called them again, of course, and they said they would research it further and bring in back in. In the meantime, we are having a heat wave. I have been able to narrow the temp at which it switches off to aprox 37. It is sort of an amusing problem as well as frustrating.
Post #8719 Fri Dec 23 2005 4:16am
USAGivGrn
Sirius Radio Repair
Finally, my Sirius Radio is repaired. To re-cap, it had intermittant failures which appeared to be related to sub-freezing temperatures. Antenna replacement did not repair it, but now a replacement of the module has solved the problem. Unfortunately, our very warm winter impeded repair since it was difficult to appreciate a problem with temperatures above 32 degrees. It was cold today, and I had great reception.
Post #12604 Thu Feb 09 2006 2:06am
grommet
United States
So, they replaced the actual Sirius module? Anyway, finally! Very Happy
Post #12606 Thu Feb 09 2006 5:42am
USAGivGrn
Yes the sirius module. I had to call sirius with a different esn number to get connected.
Post #12631 Thu Feb 09 2006 2:34pm
PaulB
Please forgive my ignorance, but what is Sirius ? Is it specific to the U.S.?
Paul RRS TDV8 - Stornoway Grey, Irory Leather with Dark Zebrano, Privacy Glass, Tow Pack.
1967 Cobra 427 S/C
1951 Vincent Comet
2001 Harley Davidson Fat Boy
Post #12633 Thu Feb 09 2006 2:42pm
USAGivGrn
It is a Satellite Radio with multiple channels of uncensored programing. I think it is only in USA and Canada, but I am not sure. It is an option on US RRS.
Post #12634 Thu Feb 09 2006 2:46pm
