Forum Gallery Shop Sponsors Directory
Home > Australia & New Zealand > Brembo Brake Pad Replacement.
Reply to topic  Down to end
Compuway
Australia 2006 Range Rover Sport TDV6 HSE Java Black
Hi Guys,
Has anyone downunder had their brake pads replaced? I have been trying to track down some part numbers online but can't seem to get anything that makes sense. I have dynamic response fitted so have Brembos on the front. Went to the dealer in Perth sometime ago and nearly fell over when they told me the price to change them. I will change them myself but need to get some part numbers to order OS.
Any leads appreciated.
Cheers.....Wayne
_________________
2006 RRS TDV6, Java/Alpaca, Dynamic Response Pack, Tow Pack, Head and Tail light protectors, 20" Stormers, Roof Rails, S/C Grill and Side Vents, Tasmods. AutoLogic mod.
1988 RR Highline, 3.5 EFI Arctic White, ARB Bullbar, Roof Rails, 15" Alloys, Front and Rear light Grilles, Side steps. (Still going strong)
Post #162429 Sat Mar 29 2008 1:02pm
Zilch
Australia 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Re: Brembo Brake Pad Replacement.
Compuway wrote:
Hi Guys, Has anyone downunder had their brake pads replaced? nearly fell over when they told me the price to change them. Cheers.....Wayne
Wayne i had an original quote from the dealer on the service of $900 for all the lot, which i thought was pretty extortionate. I went back after 3 months (projected life of the pads) and they charged me 580, so make sure they are not totally taking the p155
Jim
_________________
yet another Pommie living in Sydney
2.7 RRS TDV6, Zermatt/Ebony moooo-hide, Clear pack, Cruise, Sunroof, tow pack, RPS, Tasmod Sills, RRS Umbrella, RRSPORT rear window sticker and last but not least a "Supercheap Auto" $20 cargo net "Marvellous" Thumbs Up
Post #162431 Sat Mar 29 2008 1:27pm
Compuway
Thanks Jim sounds very similar. I must admit that was probably 4 months ago now and I haven't been back. I was talking to another guy who specialises in LR and JAG servicing in Perth who said that when the time came, I should have a look at ordering the bits direct from OS as the prices here in OZ are plain exorbitant. Just thought I would do some comparisons as I don't mind changing them myself.
Problem is I can't seem to get any part numbers. Looking at the Brembo and brake specialist sites they only seem to have part numbers for up to 2004 RR and not the Sport. I will send off a couple of emails today. Just thought someone might have tried it themselves. Monkey9952 posted a great how-to for pad and sensor replacements for his Brembo's, I will pm him to see if I can get some numbers.
Cheers....Wayne
_________________
Post #162454 Sat Mar 29 2008 11:59pm
mp3madness
Wayne,
check these out buddy.
http://cgi.ebay.com/ebaymotors/Range-Rover...enameZWD1V
If your around East Perth stop in the 22's are going onto the car end of this week Thumbs Up
Post #162456 Sun Mar 30 2008 7:41am
View user's profile Send private message Reply with quote
mp3madness
or perhaps SFP500070?
Post #162460 Sun Mar 30 2008 9:32am
Compuway
Hey mate, how's it going.? Thanks for the numbers I have sent some emails off and will ring a couple of places tomorrow.
Great mate your car has obviously arrived or is it arriving this week? Once you get the new wheels on you need to post some photos. I bet you can hardly wait.
I am still offshore at the moment but will be back in Perth on the 9th April. I'll pop down and check the beast out on the Friday.
Thanks again for the numbers.
Cheers.....Wayne
_________________
Post #162490 Sun Mar 30 2008 3:32pm
eastwop
Compuway wrote:
Hi Guys,
Cheers.....Wayne
Top : Range Rover Sport : Brakes-Range Rover Sport : Front Brakes Supercharged-Range Rover Sport
Code Description Price Quantity
SFP500070 Front Brake Pads Supercharged-Range Rover Sport
Front Brake Pads Axle Set for Supercharged-Range Rover Sport Important The Brake Wear Sensor must also be replaced when renewing Brake Pads £94.99 Axle Set
SEM500090 Front Brake Wear Sensor late models-Range Rover Sport
Front Brake Wear Sensor supercharged late models Range Rover Sport with Vin No 7A000001 onwards this item must be renewed when fitting new brake pads £13.99 each
SEM500026 Front Brake Wear Sensor Early models-Range Rover Sport
Front Brake Wear Sensor Supercharged Early models-Range Rover Sport with Vin No Upto 6A999999 Important This item should be also be replaced when fitting new brake pads £13.99 each
SEE500080 Brake Pad Retaining Pins_Range Rover Sport
Brake Pad Retaining Pins_Range Rover Sport £9.49 Per Axle Set
SEE500040 Front Calliper Seal Kit Supercharged-Range Rover Sport
Front Calliper Seal Kit Supercharged Range Rover Sport per Axle set £12.00 per axle set
SDB000624 Front Brake Discs Per Pair Supercharged-Range Rover Sport
Front Brake Discs Per Pair SuperchargedRange Rover Sport £54.99 Each
SEB500090 Front Calliper Complete Left Hand Supercharged-Range Rover Sport
Front Calliper Complete Left Hand Supercharged models Range Rover Sport £145.00 each
SEB500080 Front Calliper Complete Right Hand Supercharged-Range Rover Sport
Front Calliper Complete Right Hand Supercharged Range Rover Sport £145.00 each
http://www.connectstores.com/lr/sp_37754.html
hope this helps
Terms & Conditions | How to Use This Store
Post #166116 Sat Apr 19 2008 7:54am
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2005-2008 Martin Lewis
