![]() | Home > General > Does anyone else get a driveline shunt at low speeds?SORTED! |
| gazza500 Joined: 01 Aug 2007 Location: Channel islands Posts: 112
I have an '07 TDV6 HSE. No drive line shunt, just the annoying rattle from the dynamic response system. Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
| Diablo Joined: 28 Jan 2008 Location: UK Posts: 29 |
Gents,
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20400
Good to hear Diablo... |
| cowey101 Joined: 17 Jul 2007 Location: Gods country! Posts: 390
55 reg HSE, 31000 miles, low speed shunt problems too |
| ROB.T Joined: 21 Nov 2006 Location: LEICESTER Posts: 4
Had same shunt problem for over two years 06 HSE 33000 miles ,Do you think dealers would exchange information on fix. |
| dai748 Joined: 08 Feb 2008 Location: Wales Posts: 8
Hi,
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 1016
In LR speak = characteristic or inherent part of the car
| enzojunior Joined: 25 Jun 2008 Location: Sydney Posts: 12
My dealer said, "normal". He suggested that when these cars cruise along off-throttle, they put themselves into neutral to save petrol. So what is happening, if that is the case, is the gearbox re-engaging. Wierd?? 2006 Black/Alpaca, Hi Ice, Dynamic Pack, 19" wheels, Clear Pack... |
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 8019
Enzo I think your were told the first thing that came into the service managers head............................... when the car is cruising on a light throttle then the fuel ECU reduces and can even stop the fuelling to save fuel, the gearbox doesn't go into neutral A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
| dustin Joined: 02 Sep 2008 Location: Norcross, GA, USA Posts: 2
This clearly feels like a transmission firmware calibration issue. The transmission mechanically is probably okay. Its likely that the shift points (shift schedule) and torque converter lockup schedule were not properly calibrated from the factory. I feel the same thing on my 2006 Range Rover Sport. It feels like the transmission is "hunting" for a gear.
| XXXAngelXXX Joined: 03 Mar 2006 Location: assimilated....... by the Britts - since 1997 ! Posts: 4911
its a know prob with the 6 speed ZF auto gearbox - i had it on my former 2 Jaguars and on a friends BMW 7 but never had it with the RRS |
| 2nd Rower Joined: 12 Nov 2007 Location: VIC Posts: 325
I had one of those "software updates" at my last service having specifically mentioned this issue and TBH i haven't noticed it reoccuring since. 2008 TDV6 WHITE/EBONY
Staying - Epsom Green Defender 90 for playing off road
