![]() | Home > Maintenance & Modifications > Wheels/Tyres |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20308
A lot depends on the rim of course, but by rights you shouldn't need to do anything. |
| bwatson Joined: 17 Mar 2008 Location: london Posts: 8
| NickM Joined: 15 Feb 2008 Location: London Posts: 677
Barry had mine done by them too - they look incredible don't they??? Is your ride slightly firmer though?? Mine is but hardly a bid deal. Mate have you got a spare set of wheels in case of warranty or you not bothered?? 2007 RRS TDV6 HSE JAVA/EBONY SIDE STEPS, REAR GUARDS. 22'' STORMER WHEELS. FULL COLOUR CODE. SMOKED SIDE LIGHTS |
| FAT_RRS Joined: 18 Jun 2008 Location: COLORADO Posts: 45
what about installing the tire pressure monitors and re-calabrating the speedo? Can this be done on the RRS? Got 22'' stormers? Give me some Pictures with your tire size |
| John @ DW Site Sponsor Joined: 07 May 2008 Location: Wirral Posts: 105
The tyre pressure monitors should be a straight fit for most wheels designed for the Range Rover, who ever supplies you the wheels should know what to do and if they don't I would not use them. About re-calibrating the speedo I do not know of a way of doing it and have never seen anyone do it, but that does not mean there isn't one. The 285/35/22 tyre is out by 2.8% so when your speedo reads 60mph you are actually doing 61.7mph, if you want the right rolling radius you will need a 295/30/22, but you will get a little less side wall and worse ride.
what size tires are below? Will a 295-35-22 fit my HSE? |
The 295/30/22 will go on with no problem as long as the wheels are the correct offset. The tyres on the RRS in the pic are the 285/35/22 Toyos, most people go for the 285/35/22 as they have that little bit more side wall and take the edge of any bumps.
thanks for the pics Will a 295-35-22 fit my HSE? What about a 295-40-22? What about a 285-40-22? My wifes X5 has a nice wide tire on the rear stock. I want to be at least that wide all the way around. I think she has a 285-45-19. |
| ViewWise Joined: 13 Mar 2008 Location: London Posts: 329
Id say go with the 285-35-22 if you sensitive to bumps. Go with the 295-30-22 if you want your speedo to be unnaffected and your rear tire 1cm wider than your wifes |
Will a 295-35-22 fit? What about a 285-40-22? I will not put on a 30 series sidewall, not enough meat... |
295/35/22 should fit with out problem, but the rolling radius will be out by 3.8% so when the speedo reads 60mph you will be doing 62.3mph. If you want the extra side wall I would recommend the 285/35/22. www.designerwheels.co.uk
