![]() | Home > Maintenance & Modifications > Badge removal - standard to supercharged |
| Jonny Fresh Joined: 04 Feb 2008 Location: Manchester Posts: 689
Hi Guys,
| Rupert Joined: 13 Mar 2006 Location: Here !!! Posts: 850
I used a length of fishing gut & worked it in behind the badge to seperate it from the car with no damage.
| Steve in germany Joined: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 887
I did mine last week, just used the wife's hairdryer for 5 mins on the rear badge, got my fingers behind it, little more with the hairdryer and off it came. New one straight on in it's place. For the one in the grille I used one of those tiny electrical screwdrivers, pushed it into the badge and then pulled it straight off, OK ruins the old badge but saves risking any marks to paintwork on the grille. Speed Limits! not where I live!
Thanks
The badges have 3m self adhesive tape on them so you just peel off the backing and put it on, just use a little soapy water to clean the area before putting new badge on. Speed Limits! not where I live!
Thanks Steve. |
| CHARLES Joined: 19 Feb 2008 Location: London Posts: 12
I changed both my badges recently and found fishing line for the back badge was the best method and cleaned the area with white spirit. For the front I drilled a hole in the front green badge and used a screwdriver to wedge it out. Then I cleaned the old foam stick pad away by rubbing it with my finger which gave me a blo**y blister and then stuck the new supercharged black badge in the aperture.
| Johngilham Joined: 03 Aug 2006 Location: Garden of England Posts: 311
I put masking tape around the original so I knew exactly were to place the new badge. Heated the original with the hairdryer and it came off clean. Used a little meths to clean the residule of the adhesive and stuck the new on on. Took ten min in total. TDV6 HSE 2.7 07MY Java Black, Ivory Leather Ebony Dash, Privacy Glass, 20" 10 spoke alloys, Sunroof, Carstylingstudio Java/Chrome Grill set, Exhaust Tips by mjlperformance, Side Steps, Clear side repeaters, Mud flaps and Land Rover dust caps.
Hey guys,
| Jazzz Joined: 08 Mar 2008 Location: Moscow Posts: 61
Gentlemen,
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20671
Nobody's trying to fool anyone Jazzz.... it's just that the common belief amongst a lot of people is that the SC grille and vents look better than the standard components. If folks want to make their cars look better then I'm all for it |
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 20864
I just like the SC bit's think they look much better then the green badges i was gonna get a SC but i have the SL for power so no need for the SC in the RRS |
| All times are GMT |
Staying - Epsom Green Defender 90 for playing off road
