Forum Gallery Shop Sponsors Directory
Home > Maintenance & Modifications > Hi newcomer here!....got a question about side steps...
Reply to topic  Down to end
AJ
Hi all....
Excellent forum...hopefully youll see me contributing on here soon, as im currently looking for a TDV6.
My first question is.... some of the RRS's im looking at have side steps and mudflaps ...how easy are these to remove do they leave any unsightly marks or holes ect?
Post #156327 Tue Feb 19 2008 2:21pm
View user's profile Send private message Reply with quote
mambo
Side steps can be taken off without any problem, some trim needs to be cut to install mudflaps so they may leave a mark.
Post #156333 Tue Feb 19 2008 2:47pm
AJ
has anyone else removed these....are any marks visable? is there any chance for water leakage?
....shame cos i think the lines of the car look better without the flaps - so might have to pass up on the one that iv found....
Post #156344 Tue Feb 19 2008 3:52pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Welcome, AJ. A 4-5" section of rubber moulding around the front wheel arch is cut to get the front mud flaps to fit flush with the body and to screw them on. So, there will be a couple of screw holes left exposed where the rubber moulding used to be after you remove the flaps, no biggie. Here is a picture of mine after I removed the front flaps, you can see the two holes... I had to remove them when I installed my rock sliders, but I have since put them back on after a bit of creative "cutting" of the flaps around the sliders (I couldn't find a close-up shot, sorry):
If you really wanted you could just buy two new mouldings for the front wheel arches from your friendly stealer, I can't imagine them being very expensive. They are just reinforced strips of rubber. The rear mud flaps don't require modifications of any kind to install, so no signs of them should remain if you take them out. As far as the side steps are concerned, the two replacement rocker panels necessary for their installation have cutouts on the bottom (for the six bolt-on brackets that stick out from under the car to support the steps.) The rocker panels will likely stay after the runners and brackets are removed - unless the owner/dealer saved the original ones, in that case they just snap off / snap on - but they are hidden behind the doors anyway, and unless you look under the car you really can't tell the difference between the two.
_________________
Post #156404 Wed Feb 20 2008 1:48am
AJ
Thanks for the informative reply....i think i will get the trim/moulding replaced if the situaution arrises and its good to know that i can take off the steps and then put them back on if i change my mind.
btw your car looks great in white... would get it in that colour but theyre really hard to find in the uk.....not sure id be brave enough to take it on the rocks though!
Post #156450 Wed Feb 20 2008 11:28am
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Not sure if its been said before 'white is the new black!'
_________________
RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
IN PAIN!
Post #156464 Wed Feb 20 2008 12:11pm
Cyprus 2006 Range Rover Sport TDV6 HSE Java Black
Not sure if it's been said before 'ONLY LR OE STEPS WILL DO!'
_________________
06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods, Black Badge Soon...
COME TO TROTTERLAND
http://trotterland.myminicity.com
HELP BUILD ROADS IN TROTTERLAND
http://trotterland.myminicity.com/tra
HELP JOBS IN TROTTERLAND
http://trotterland.myminicity.com/ind
Post #156549 Wed Feb 20 2008 6:27pm
Location: Growing old is mandatory; growing up is optional.
I don't know it has SuperT?
_________________
RRS TDV6 Gone but still around
BMW 320D M Sport
And A Van For The Dog
Oh and i love the girlzzzzzzzzzz!!!
Post #156557 Wed Feb 20 2008 6:40pm
_________________
COME TO TROTTERLAND
Post #156559 Wed Feb 20 2008 6:44pm
Let me try again Embarassed
I don't think is has been said before?
_________________
BMW 320D M Sport
Post #156561 Wed Feb 20 2008 6:46pm
Bobby
Bow down Rolling with laughter Rolling with laughter
Good morning! Thumbs Up
_________________
Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #156593 Thu Feb 21 2008 12:14am
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2005-2008 Martin Lewis
