![]() | Home > Technical > Lop-Sided TDV8 and Key Memory Issues |
| Kaine Joined: 27 May 2006 Location: Hills of Shropshire Posts: 6019
Hi
| TB Joined: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 4547
Definately sounds like a faulty ride hight sensor to me.
| PLidds Joined: 23 Jul 2007 Location: Germany Posts: 27
Good luck in resolving the fault with your moter.
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1729
PLidds, there was a bulletin on this early this year...
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 18718
As Kaine said just a sensor problem
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14138
As for you key settings check that your car battery is OK if not that get them to check your ECU. |
PLidds, any luck with the 'Lop-Sided' issue? |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: Me fail English? That's unpossible. Posts: 18511
Must be fixed and now he can't pull himself away from the car to come back and tell us! |
Sorry all; been away working for the week for a change. Not had time to check-in. Picked the car up this morning from the local stealer and as predicted by you clever folk it was a sensor issue this time. Wonder how long this will last until it starts to list again. Is this generally a recuring problem?
Been down the autobahn and now the rear left brakes are sticking. Stank and was extremely hot when I got back and the excess brake dust also gave things away. Tried applying and releasing handbrake a number of times but still seems to drag significantly. Another trip back to the dealer needed. Also Sat Nav brigthness is always dull now even with lights off and limbar control has fell off seat. I'm sure all will be sorted one day. |
