Home > Technical > DVD troubles
Bobby
Umbertob Thumbs Up Thumbs Up Thumbs Up Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #149569 Mon Dec 24 2007 12:07am
Good to hear - maybe you should feed this back to your service dept, with an invoice for your time Wink
Post #149575 Mon Dec 24 2007 9:25am
Nice one Umbertob Thumbs Up RRS TDV6 Gone but still around
Post #149591 Mon Dec 24 2007 9:59am
gseum
Germany 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
umbertob wrote:
Probably too late, but this is from an old DVD troubleshooting bulletin.
Quote:
VIDEO SIGNAL IS INCORRECT
NOTE: If an incorrectly formatted DVD is installed in the DVD-C (for example a Region 2 PAL DVD disc used in a Region 2 NTSC DVD-C player) the message 'VIDEO SIGNAL SYSTEM IS NOT CORRECT' will be displayed on the front and rear LCD screens.
1. If the message 'VIDEO SIGNAL SYSTEM IS NOT CORRECT' appears, investigate the possible Root Cause:
• Selected DVD player video settings are the wrong format.
• DVD disk loaded is of a different format than the DVD.
• Corrupted or damaged (scratched or dirty) disk cannot be read.
2. If a cause is determined, make the appropriate corrections as follows:
• Check and replace any damaged disks.
NOTE: The remote control can select between the NTSC and PAL
video formats. The message should clear once the correct video
format has been selected.
• Press and hold the On/Off switch at the side of the remote control to
select the correct video format. (Figure 1)
• If the message remains, cycle the vehicle ignition.
• If required, disconnect and reconnect the vehicle battery.
Check to make sure you are not in the wrong video format using the remote (e.g. NTSC and trying to play PAL encoded discs) as per bold note above... It may be as simple as that. The On/Off button is the small one on the upper left side of the remote. Good luck, keep us posted!
Hi,
I have a LR4 modell 2010 from the US, but navigation harddisk was changed to european version. The DVD changer for RSE also shows "Video signal system is not correct" with a PAL DVD inside.
Unfortunately your solution does not work - i tried on/off for several seconds with different switch settings (left or right monitor).
I think the DVD changer is set to NTSC and the head unit to pal?
Any solutions to change the changer to PAL?
Thanks for your advice
gseum
Post #306690 Tue Jul 19 2011 10:24pm
mse
Hi,
gseum
If its the facelift disco then you can change the pal/NTSC from an option in the front unit. Have you looked in your manual?
Also remember a 2010 vehicle is under warranty Mike
2014 Facelift Discovery
Post #306692 Tue Jul 19 2011 11:36pm
gseum
Hello,
yes it's a facelift modell - but changing the mode from ntsc to pal or vice versa doesn't solve the problem. Sad
Warranty is there, but it is an self imported car from the us and the german dealers are pretty unused to these kind of problems...
Regards
gseum
Post #306696 Tue Jul 19 2011 11:46pm
mse
Did you have the entire unit changed, or just the maps downloaded?
You might find the DVD unit in the rear is region locked Mike
Post #306703 Wed Jul 20 2011 7:31am
gseum
Hi,
the Navigation harddisk was changed - not the DVD changer.
This is NOT a region code problem. The PAL DVD was region code free (all codes enabled), but was not working.
I converted the same DVD to a NTSC DVD - this is working properly.
So this is a NTSC / PAL problem. The changing to PAL does not work in my 2010 modell - not via touchscreen, not via remote control...
What ist the Alpine changer article no. for a european one? Probably it is the easiest way to get one from ebay?
Regards
gseum Discovery 4/LR4 5.0l V8 HSE from US
- RRS 2010 TDV6 gone
Post #306707 Wed Jul 20 2011 8:00am
mse
Sounds like you have identified you own fault, as it should work tried mine this morning Mike
Post #306773 Wed Jul 20 2011 2:11pm
gseum
... but the screen format SHOULD be changeable from NTSC to PAL, but is not working. So I think, something is wrong... Discovery 4/LR4 5.0l V8 HSE from US
Post #306779 Wed Jul 20 2011 2:38pm
mse
my point is - it is, so thats your fault to get fixed Mike
Post #306844 Wed Jul 20 2011 9:33pm
ujensen
Brazil
Anyone found a solution for the "video signal system is not correct" issue ? I had this once before and pressing the on/off in rear seat remote control solved the issue. Now it happened again, after a dead battery, but the procedure is not working anymore. Any idea what i could try to solve it ?
Post #543662 Mon Dec 18 2017 2:30pm
