Home > Technical > PDC Inactive
RRSSS
Bahrain 2010 Range Rover Sport Supercharged Nara Bronze
PDC Inactive
Hi guys,
wow, well its not even been a month and I've already got my first problem Sad
Usually, when I put the car in reverse, the PDC (parking sensors) become active and do their job. However now, they would come on as usual but after a couple of seconds the button starts flashing and a warning message comes on the info screen, saying something like "Front Parking Sensors Inactive".
My sensors now do not work at all, everytime I switch on the PDC, the button starts flashing followed by the error message.
Has anyone else encountered this problem? I'm taking the car in to the dealership on Wednesday to see if they can cure it.
Any thoughts much appreciated.
Thanks.
Post #122290 Mon Jul 02 2007 9:26am
What has probably happened is that one of the connectors to one of the 8 parking sensors has come loose. If one is not connected the whole lot fail. I had this when I fitted the winch plate and took 2 sensors off. Very simple fix. 2005 Zambezi TDV6 - Gone but not forgotten
Post #122295 Mon Jul 02 2007 9:42am
RRSSS
Thanks VA, will mention it to them tomorrow and see what happens...
Post #122678 Tue Jul 03 2007 5:55am
G4LAND
Spain
May be an obvious observation; have you clean all sensors? It can be a reason. Yuri
(ARS) XE1UN
13 RANGE ROVER SPORT HSE SDV6
Orkney Grey/Black
(Spain)
07 RANGE ROVER SPORT HSE TDV8
JavaBlack/Black
(SOLD)
05 DISCOVERY 3 G4 V8
(Spain)
02 DEFENDER 90 BLACK LE TD5
(SOLD)
13 FREELANDER 2 (LR2) HSE Lux SI4
Havana/Black
(Mexico)
Post #122699 Tue Jul 03 2007 9:25am
RRSSS
Took the car down this morning and explained that it could be a loose sensor.. They checked it out and found that one of the front sensors was faulty. And, as VA correctly pointed out, if one doesn't work, all of them decide to do the same..
End result, they changed the faulty sensor and I picked it up this evening.. my PDC is alive again Smile
Post #123022 Wed Jul 04 2007 6:01pm
RRSSS
Glad you got it sorted - by the way, did I miss the pics of your RRS after all the colour coding?
Post #123027 Wed Jul 04 2007 6:11pm
RRSSS
Thanks Kaine.. the PDC's a real lifesaver in the RRS
pics should be in the "My RRS Section", under my first post, what dyu think of the colour?
Post #123031 Wed Jul 04 2007 6:17pm
