Home > General (L494) > Can anyone recommend a good LR Indy...
Karlp606
In the Hull and East Yorks area - Cracked Manifold unfortunately so looking at getting both done whilst having the work done on it.
Post #640743 Wed Mar 27 2024 1:42pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
I use JAS Land Rover Specialist in Pocklington in York. They are very good. They do all the servicing on my car and they can update the electronic service history on the LR website too. Probably not too far from you.
Post #640750 Wed Mar 27 2024 5:52pm
Johnrrs
Their prices are good too. When my car needed the 7 year service with all the belts etc I got 3 quotes , 1 from main dealer, 1 from Green Oval and JAS. JAS were cheapest and I’m glad I chose them. Green Oval were more expensive than the main dealer and when I told them this they didn’t seem to care. The only thing with JAS they are always busy so you need to book services well in advance
Post #640751 Wed Mar 27 2024 5:56pm
Karlp606
Thanks mate - well I have warranty until June although I thought I did but they’ve emailed back to say the manifold is not covered under the 4 star agreement , but it states exhaust inlet and exhaust valves under engine , please see attached . Are they trying to have my pants down here.
Post #640753 Wed Mar 27 2024 7:15pm
Johnrrs
I too have a warranty but an aftermarket one with warranty direct and they don’t cover the manifold either. I have had quite a few warranty claims and all have been successful. JAS did all the calling to them to get them approved. Another reason why I use them. Who is your warranty with?
Post #640754 Wed Mar 27 2024 8:09pm
Karlp606
I’ve got extended warranty with the dealership where I purchased the car - Eclipse Car Sales in Winchester they have a warranty program which is underwritten by another company.
They’ve been good in the past with other issues I’ve had , since there based in Winchester they’ve arranged for local garages to do warranty work previously and also paid them directly.
It ends in June so I’m not sure if there trying to fob me off , but as you can see with the booklet I have the 4 Star warranty which states exhaust inlet / valves which I presume that to be the manifold?
Post #640761 Wed Mar 27 2024 10:08pm
Johnrrs
It’s worth giving JAS a call to get a rough idea on costs to replace the manifold then ring round a few other specialists for more quotes if the warranty people won’t cover the manifold
Post #640762 Wed Mar 27 2024 10:24pm
Johnrrs
Just had a flick through my warranty policy and they class the manifold as part of the exhaust system hence why it’s not covered on my warranty either. How do you know it’s the manifold that’s at fault?
Post #640763 Wed Mar 27 2024 10:31pm
Karlp606
Had a smoke test done and found a small crack on the drivers side.
The warranty is a dealer fund agreement backed by DGS.
Quite annoying they don't cover the manifold :/
What would you consider the exhaust inlet on a engine....
Post #640764 Wed Mar 27 2024 11:12pm
The warranty only covers engine internals - the manifolds are internal components, they're external.
Looks like the sort of warranty that appears to be comprehensive (lots of words so must cover a lot, surely) but the detail is that they cover very little really. Push rods? Distributor drives? Is it aimed at modern cars or classics? 2012 SDV6 - it's missing a couple of cylinders
Post #640765 Thu Mar 28 2024 7:24am
Karlp606
So looks like not under my warranty which is a bummer Sad
RRSTDV8 - Presume you meant arent covered as the manifold is not internal Sad
Spoke to my local indy Mark @ LRS Hull previously did a lot of work on my old defender and timing belt on my L494 his qouted £800 for 1 side or around £1000 for both manifolds so I cant complain with that , MOT/SERVICE is due May so will prob get him to do MOT/Service same time.
Thanks for the help and repsonses guys.
PS John JAS work with LRS if ones busy they recommend each other Thumbs Up
Post #640768 Thu Mar 28 2024 11:57am
Johnrrs
Ah that’s good to know
Post #640780 Thu Mar 28 2024 5:35pm
Yes, typo on my part. Embarassed 2012 SDV6 - it's missing a couple of cylinders
Post #640783 Thu Mar 28 2024 6:35pm
Montipora
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Just had both sides go on mine. £1400, luckily my warranty (RAMP) did cover it
Post #640822 Sat Mar 30 2024 10:21pm
