Home > Maintenance & Modifications > Trafic indecators..... |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4845 |
Have you checked that you have not got a blown bulb?
Mon Mar 25 2024 8:22pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4793 |
You have a bulb failed |
Mon Mar 25 2024 8:31pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 330 |
This is intended to show a blown bulb but on the odd occasion over the last 40 years as an auto electrician I have found one bulb not to be drawing sufficient current so although it flashes it triggers the fail mode ..just change the bulbs on one side. Always listen to old people or when they die you will live on in ignorance.
Tue Mar 26 2024 8:00am |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 310 |
Hi Andy and Col. Traffic indicator lights are working okay, however, I have recently changed the rear off site lighting unit - so what am I looking for to find the fault? Andrew Kennedy |
Tue Mar 26 2024 10:30am |
On the unit you replaced.
Tue Mar 26 2024 10:37am |
Okay now I know....learning all the time....bulb on the front offside blown. Thanks for advice!!!! Andrew Kennedy |
Wed Mar 27 2024 8:22am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
A nice simple, cheap fix is always a pleasure. 2012 SDV6 - it's missing a couple of cylinders
Wed Mar 27 2024 8:31am |
