Home > Faults & Fixes > RANGE ROVER SPORT 2009 TDV8 BLOWN TURBO'S HELP
craigdunne
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Alaska White
Hi, my RR sport 3.6 TDV8 gave up the ghost on Saturday. Was driving, accelerated and suddenly lost power, went into restricted performance and smoke coming out of engine. Had it towed to a garage who have said the turbos have definitely gone, but also the engine is not turning so that could be gone also. The price given to replace the turbo's alone is £3000, but that did include removing excess oil from engine and replacing the oil. Im not a mechanic but it seems a lot of money. He did say they would be new turbo's not reconditioned. What's everyone's thoughts?
Post #635944 Mon Sep 18 2023 6:34pm
Dave B
Bearing in mind it's a body off job, it's a fair price.
Turbos alone from LR will cost over £2k, the same direct from Borg Warner slightly less than £2k.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #635961 Tue Sep 19 2023 4:08pm
£3k to replace two turbos is not a lot of money. Well, it is a lot of money but it's not for the job described. Unless that's just the labour charge, in which case it is excessive and they want you to go somewhere else.
The turbos alone will cost you that.
However, if it won't turn over because it's full of oil, then the turbos might be the least of your worries. A hydro-locked engine is likely to be scrap/uneconomic to repair. 2012 SDV6 - it's missing a couple of cylinders
Post #635965 Tue Sep 19 2023 4:40pm
Disco_Mikey
Got a good used engine here, if its any use Thumbs Up
Post #635980 Wed Sep 20 2023 7:31am
