Home > Maintenance & Modifications > ZF6hp26 swap |
John R Hickman Member Since: 26 Jan 2023 Location: Dudley Posts: 43 |
Are these transmission box's interchangeable between models? for example disco 3 2.7 into a sport 2.7 or 4.2sc into a 2.7 and how about the L322 disco 4 etc. I've been on the look out for a lower mileage example but not sure what will fit. I have a chance of one from a 4.2sc ffrr. I'd have to use the mechatronic from my own box with it. 2008 RRS 2.7 TDV6 S Poverty model |
Sat Sep 09 2023 1:11am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4793 |
I think the 4.2 maybe different.
Sat Sep 09 2023 8:15am |
Done some cross referencing and found that RRS 2.7, 4.2sc, 4.4 all have the same gear ratios the difference as i can see is the torque converter size. 255mm = 2.7, 260mm = 4.4, 280mm =4.2. Disco4 2.7 has same ratios and torque converter as rrs 2.7 and 4.0L has same but 260mm torque con. I can't find specs for the ffrr to compare though. 2008 RRS 2.7 TDV6 S Poverty model |
Sat Sep 09 2023 2:01pm |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 |
You'll need to swap over the mechatronic unit also - e.g. keep the one that belongs to your car. Unless you feel like re-coding the new one to your VIN. That's the easy part of course! Every home should have one!
Tue Sep 12 2023 6:22am |
