Home > Maintenance & Modifications > 2007 RRS 2.7TD V6 brake booster(servo) code/ which one?
D500s
Slovenia 2007 Range Rover Sport TDV6 HSE Orkney Grey
I have a faulty brake booster and I need new.
As far as I know there is LR part SJJ500070, that fits.
But there is also a SJJ500080 code, that fits V8 diesel and gasoline.
I wonder, can I fit SJJ500080 instead of SJJ500070?
SJJ500080 is MUCH cheaper, less than half the price....
I hope someone can help me save some money on my old girl...
I watched this video, when he fitted 500080, but it was faulty. I wonder, if the wrong one was the problem.
Thank you
Post #634869 Sun Aug 06 2023 2:04pm
Disco_Mikey
TDV8 servo can be fitted to the TDV6 without issue
The underlying cause will need rectified though (usually oil ingress from the vac pump) otherwise it will only happen again
Post #634870 Sun Aug 06 2023 2:08pm
D500s
Thank you for your answer, that is good news.
I have already replaced vacuum pump Sad
Thank you again
Post #634871 Sun Aug 06 2023 2:13pm
