Home > Faults & Fixes > Central locking fault on 1 door
savi18
New Zealand
Just started with this fault, fob is programmed to unlock all doors on 1 press however 3 doors unlock including boot but o/s/r door need to press fob again to unlock this door, have tried pressing both lock/ unlock on fob together to reprogram but still has same fault on door, 09 RRS, cheers [/u]
Post #634212 Tue Jul 11 2023 10:41pm
Had same fault on mine, same door, although a slightly later car, new door latch/lock sorted it. Not uncommon fault.
Post #634213 Tue Jul 11 2023 11:33pm
savi18
New Zealand
Thanks Col, did you replace your self, secondhand or new, Cheers Savi18
Post #634215 Wed Jul 12 2023 5:53am
Yeah, did it myself, bit of a pain but not to bad I actually took the outside handle off as well which makes it a lot easier, only downside is there's a good chance of breaking the retaining lugs on the small part of the external plastic cover, fortunately I had some spare one's. I fitted a genuine L/R lock/latch assembly from Advanced Factors cost me $300.00 total shipped in direct from the U.K. dealer here wanted $700.00. certainly wasn't going to chance a £25.00 ($50.00) Chinese special.
Post #634216 Wed Jul 12 2023 7:45am
savi18
New Zealand
Thanks Col, $255 from Rimmer Bros plus shipping, will leave it till summer and sort it then.
Savi18
Post #634218 Wed Jul 12 2023 10:07am
Meiang
My drivers side rear door lock failed about two years ago, but after a couple of weeks it fixed itself and has not been a problem since. Recently the driver door lock requires the button to be pressed twice to unlock and requires the door to be manually locked. I am waiting for it to fix itself.
Post #634242 Thu Jul 13 2023 4:21pm
