Home > Faults & Fixes > L320 NSR Indicator Not Working
BlackThorn
Hi All,
The NSR indicator has stopped working on my L320. It's a 2011 so is the facelift model with the LED indicators as standard. Just the NSR rear doesn't work and the light on the dash flashes faster than normal. The NSF work's fine.
Initially I thought it was a fault unit so replaced the whole thing but the issue persists.
Can anyone point me in the right direction or where to start fault finding please?
Thanks 2011 (L320) 3.0 TDV6 HSE
Post #633764 Fri Jun 16 2023 8:54am
NoExpert
Check the ground points near the light, they have a tendency to fail. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #633765 Fri Jun 16 2023 9:08am
BlackThorn
Thanks for the quick reply, I'll have a look and see if I can track it down. 2011 (L320) 3.0 TDV6 HSE
Post #633769 Fri Jun 16 2023 9:19am
BlackThorn
It turns out the issue was the unit itself. Whilst the side and brake light was functional, the indicator didn't work. I cleaned out the electrical connector and wiring harness but still no joy so I plugged in the new unit I bought and it's all working.
The first time I tried the new unit the issue must've been a bad connection.
Thanks Thumbs Up 2011 (L320) 3.0 TDV6 HSE
Post #633771 Fri Jun 16 2023 9:43am
