Home > Maintenance & Modifications > Engine air leaks 4.2 SC |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 294 |
Here you go
Fri May 26 2023 1:05pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 199 |
Many thanks - there’s a few pipes under the cover which could be the cause, so will see what the garage say.
Fri May 26 2023 1:22pm |
Turns out it’s a crack in the air filter housing. Need to fully investigate where, but nothing a bit of either superglue, plastic welding, or a replacement housing can’t sort out. |
Mon May 29 2023 8:30pm |
Apparently the crack is where the breather pipe connects to the large plastic air intake manifold. The car's back from the garage now, so I'm unable to have them point it out to me, so would be grateful if a kind soul could post up a pic or two of exactly what this part is. 4.2 SC.
Wed May 31 2023 1:10pm |
Managed to get this sorted - the air intake ducting is part nr PHD500055 or 4619625903
Sat Jun 10 2023 9:29am |
Update - all sorted ! New plastic intake manifold arrived, popped it on and air leak codes have now gone.
Wed Jun 14 2023 8:15pm |
