Home > General > Front door won't open unless put hand in handle |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
Sounds a bit like the release cable from from the internal handle to the latch may have snapped, disconnected somehow or not refitted correctly when lock changed, not sure if the window linkage could catch the cable in someway when it went down if the cable had not been fitted/secured correctly, only a suggestion though, would need to remove door trim panel to have a look.
Thu May 18 2023 11:07pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
It it doesn't unlock with the key fob, but unlocks with the Keyless system, then its more than likely a faulty latch
Fri May 19 2023 6:28am |
pbcb2020 Member Since: 23 Jan 2020 Location: Cardiff Posts: 18 |
Appreciate the reply Disco_Mikey.
Fri May 19 2023 9:49am |
The internal release lever is connected to the latch by a short bowden cable not a electrical cable, bit like a very short pushbike brake cable for want of a better description.
Fri May 19 2023 9:55am |
Thanks. Is that something I could look at ? And do you need to take whole door unit off, similar to what need to do ro replace the lock unit |
Sun May 21 2023 3:52pm |
You will need to remove the door trim panel to get to it, not the whole door though
Sun May 21 2023 10:04pm |
