Home > Maintenance & Modifications > Disc painting Advice |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
It will eventually start to disappear, although what is the most important bit is the preparation of the disc before painting. They are covered with stuff that needs several sessions with rubbing alcohol to get rid of it, and only then it does make sense to paint. A good high-temp paint will obviously last longer. Do not get tempted with too many layers, though, after the 3rd-4th layer the subsequent will not make the coating last any longer. Regards etc.,
Sat Apr 01 2023 5:07pm |
5.0 ltr Frank Member Since: 28 Mar 2023 Location: Birmingham Posts: 37 |
I am in the process of cleaning / preparing the discs to apply a Clear Laquer ( ordering Monday)
Sat Apr 01 2023 5:27pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4847 |
I have used this in the past, personally found it excellent and lasted well, as said preparation is the key.
Sat Apr 01 2023 10:45pm |
^ i was going to order this...( any experience of )
Sun Apr 02 2023 9:59am |
I also used the VHT stuff when I replaced the discs on my s/c as options are bit limited down here, it is holding up really well for a couple or so years now used it on the rear calipers as well as the original red finish on the factory calipers was crap, but do have the added advantage that they don't use salt on the roads here.
Sun Apr 02 2023 10:09am |
^ You've convinced me...... I'm on it.
Sun Apr 02 2023 10:13am |
Sun Apr 09 2023 3:56pm |
