Home > Maintenance & Modifications > Suspension confusion.. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4793 |
So with fuse removed, right front dropping ?
Sun Mar 19 2023 1:33pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 199 |
Thanks Andy - yep, front right dropping this time and pretty quickly. Typically the tab on the electrical connector broke off and I didn’t realise, so having stripped everything and put it back together I was getting a suspension fault. Stripped down again to find the connector hanging loose.
Sun Mar 19 2023 1:45pm |
If a tiny seal falls out the valve block, it will blow the connector off. Even with a good tab.
Sun Mar 19 2023 2:30pm |
Not sure I’m understanding that correctly Andy - surely the electrical connector and pressurised side aren’t connected ?
Sun Mar 19 2023 2:48pm |
Connector shouldn’t be pressurised. But as said. If a seal is lost it can be! Ask me how I know!
Sun Mar 19 2023 2:53pm |
New world record for stripping and rebuilding everything, including stripping down the valve block !
Sun Mar 19 2023 4:34pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 294 |
Well done that man ..... |
Sun Mar 19 2023 4:48pm |
Not so fast sunshine ! (as my dad used to say..)
Sun Mar 19 2023 5:21pm |
Oh yeah. Sounds like middle valve block
Sun Mar 19 2023 5:45pm |
It’s front right dropping - used to be front left.
Sun Mar 19 2023 7:57pm |
I guess you need to put soapy water around the valve block and pipe connector and may as well do front strut. (while it has air in the system!) see if it has bubbles.
Sun Mar 19 2023 8:08pm |
The packing silicagel would get rid of the issue of degradation, but not sure it would have the same drying ability. |
Sun Mar 19 2023 8:11pm |
And another update...
Wed Mar 22 2023 1:49pm |
More updates - front valve block rebuilt and installed (twice).
Fri Mar 24 2023 1:47pm |
