Home > Technical > RRS TDV8 2010 - A few errors |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
I think what you could do and is common is to clear the codes (now you've made a note) and see what reappears. Those that do are then your items of interest. 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri Mar 03 2023 8:29am |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 193 |
Hi Steve, sorry I should have said in my opening post that these are the codes that I found to reappear after clearing them all.
Fri Mar 03 2023 8:57am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
Full code description and possible causes and action, which might point you in the right direction.
Fri Mar 03 2023 8:59am |
Thanks Col, I'll have to have a look at it once I get home.
Fri Mar 03 2023 9:15am |
Well fixed the parking sensors, dropped the rear bumper skin off to find the brown wire on
Sat Mar 11 2023 5:03pm |
Thought I'd give a quick update on the faults.
Sun Oct 22 2023 2:11pm |
Old filter
I have also had an intermittent error relating to the ambient light sensor and have noticed that sometimes the headlights come on during a sunny day.
Sun Oct 22 2023 2:14pm |
