Home > Technical > Steering Angle Sensor shows 5773.5 and wont recalibrate |
SimonG Member Since: 13 Feb 2023 Location: Buckinghamshire Posts: 3 |
Hello all,
Mon Feb 13 2023 3:12pm |
Bit of an update.
Tue Feb 21 2023 11:35am |
Azi Member Since: 06 Mar 2023 Location: dontneedtoknowthatbruv Posts: 1 |
Hello, cant pm so I write here
Mon Mar 06 2023 2:34pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 422 |
Did any of you go through the “install new module” process in JLR-SDD or other capable diagnostics? Not recalibrate, that probably won’t work and especially won’t with secondhand units. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sun Sep 10 2023 4:17pm |
MattJ14 Member Since: 10 Sep 2023 Location: London Posts: 3 |
Thank you - That's helpful as hadn't realised I had to install as new module. However, sadly that doesn't work either. Goes to initialise and calibrate module and the process fails.
Sun Sep 10 2023 5:04pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
I've had quite a few cars in from other local garages unable to calibrate SAS using generic diag gear
Sun Sep 10 2023 7:52pm |
Hmm. sounds like I should have put my hand in my pocket and spent a bit more than my Foxwell diagnostics. Although it has done most stuff so far pretty well. |
Mon Sep 11 2023 11:31pm |
