Home > General > Roof Rails |
d3matt Member Since: 11 Jul 2005 Location: Oxfordshire, UK Posts: 730 |
Having just fitted them, yes the dealer is correct as once fitted they cannot be removed as it would leave holes in the plastic trim on the roof.
Mon Feb 13 2006 10:03pm |
AC Member Since: 01 Nov 2005 Location: Chicago, Il Posts: 12 |
Matt,
Thu Feb 16 2006 3:52pm |
That is true - each rail is held down by three screws. If removed, you could block the three large 19mm holes in the trim with rubber grommets (electrical grommets are 20mm I think), so that water doesn't get trapped under the trim. Matt
Thu Feb 16 2006 4:01pm |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2567 |
Roof rails that can't be removed? Who designed those? Mickey Mouse? L319 D4 HSE
Thu Feb 16 2006 5:21pm |
The rails can be removed. It is just the side tracks that are fixed. Matt
Thu Feb 16 2006 7:03pm |
I know, but still, not great design is it? L319 D4 HSE
Fri Feb 17 2006 12:02pm |
The Sport should come with fixed side rails like estate cars and many other 4x4s do. Matt
Fri Feb 17 2006 1:10pm |
Robbi Member Since: 14 Jun 2005 Location: Channel Islands, Guernsey Posts: 130 |
Maybe someone will design a roof rail aka X5/XC90. With the right design could look good. Rob *Gone - HSE TDV8 Rimini Red + Tasmod sill plates |
Sat Feb 18 2006 9:39am |
vip-culture.com Member Since: 12 Feb 2006 Location: The OC Posts: 86 |
Matt,
Wed Mar 01 2006 7:22am |
No. The fire extinguisher came with a wire bracket - as they all do. I simply fixed this to the cross bar under the seat with two self tapping screws. Very simple. Matt
Wed Mar 01 2006 10:05am |
Full details on fire extinguisher mounting in this thread http://www.rrsport.co.uk/forum/viewtopic.php?t=1265 Matt
Wed Mar 01 2006 10:11am |
thanks matt, i just notice that post now www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
Wed Mar 01 2006 7:41pm |
