Home > Technical > New TDV8 with PTI as standard, but says no phone fitted?????
Rooleeds
Hi,
Took delivery of the TDV8 today (Hurrah), and got straight to setting up all the gadgets.
I paired my phone, (Blackberry 8100), via bluetooth, Land Rover appeared on screen, put in code and says paired on the phone, BUT when I press the phone symbol button it reads "NO PHONE FITTED"
Im sure there is as the green and red steering wheel controls are there, also there is a connection thing on the lid of the cubby box.
Am I doing something wrong, or do I need to buy any "extras" to use the phone system in the car??????
Thanks.
Post #98669 Thu Mar 29 2007 11:42pm
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
Sounds like a quick trip back to the dealers for advice, wiring check or a "while-you-wait" ECU flash? Let them solve the issue. I have my phone paired on Blutooth, but instead use an old Nokia handset permanently mounted in the armreat cradle. Different number, but saves messing around. That works ok with green/red steering wheel buttons and I'm sure blutooth should do the same. It'll only be a minor hiccup, something silly probably. You HAVE read the handbook, haven't you??? Good Luck! Thumbs Up MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #98677 Thu Mar 29 2007 11:54pm
My nokia N80 is permanently paired via bluetooth and works fine with the green and red stering wheel controls - as should yours - so check it out with your dealer
Post #98680 Thu Mar 29 2007 11:59pm
tartan terror
Congrats on your new TDV8! Thumbs Up
How about a few pics? MY08 RR Sport TDV8 HSE Java Black; Black Leather; Privacy glass
Post #98715 Fri Mar 30 2007 8:58am
Rooleeds, the Blackberry 8100 is fully supported on software version 4.2.0.51 according to the LR approved phones guide. Check the software version on your Blackberry and if it's the right version then as others have said take it back to the dealer.... it SHOULD be working 100% Very Happy
Post #98717 Fri Mar 30 2007 9:03am
Geek!
Rolling with laughter Rolling with laughter Sorry
MY N80 doesnt work with the buttons either only if i get a call can't make a call from then as in redial RRS TDV6 Gone but still around
Post #98720 Fri Mar 30 2007 9:05am
JayMann wrote:
Geek!
Thankyou! Cool
Post #98723 Fri Mar 30 2007 9:08am
Brian Mason
Geek? I'd like to be able to call you a FOOL Shmooge, but clearly you're not? No..., you're obviously a SMART-ARSE instead! Whistle MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #99034 Sat Mar 31 2007 5:25am
I'm happy to meet you halfway, Brian... I could be a FARTARSE! Thumbs Up
Post #99716 Mon Apr 02 2007 11:19am
Rooleeds
Thanks guys. Sorry I couldnt reply sooner.
All is well and working 100%, for some reason it paired with the car but wouldnt connect until I parked up, went inside for the night, got back in next morning and Bingo! "PHONE ACCEPTED" appeared, and has done ever since.
Post #99792 Mon Apr 02 2007 2:45pm
tasmod
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
Post #99828 Mon Apr 02 2007 5:26pm
