Home > Maintenance & Modifications > Facelift L494 Bumper Fitting to 2014 5.0 S/C - Exhaust Mod??
911-RRS
Hi Everyone.
I have purchased a 2019 Facelift Rear bumper fit to my 2014 5.0 S/C.
I have to modify my existing exhaust as it clashes with the bumper static 'exhaust tips' on the new bumper.
Has anyone done this previously and if so can they advise how much to cut off / How to modify? My feeling is to cut the exhaust just before the 'double' skin part of the tail pipe - about 10mm out from the exhaust hanger. But this maybe too short (Although the fumes will still obviously exhaust).
Also the exhaust hanger 'Diamond' rubbers clashes with the new bumper tip steelwork. Source straight rubbers or fettle the steelwork?
Images attached.
Any experienced advice welcome!
James
Post #619377 Sun Nov 21 2021 3:49pm
jimbg
 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #619379 Sun Nov 21 2021 4:06pm
Tyrefitter
I’ve done the same mod & you need to cut the tail pipe off.
 Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #619392 Sun Nov 21 2021 7:04pm
911-RRS
Thank you 'Tyre Fitter'.
Can you tell me where you cut the tail pipe and does the 'stump' still protrude inside the New Tip metalwork?
I think your exhaust may also be a smaller Diameter? What car do you have?
Also how did you get over the Exhaust Mounting Rubber Clash with the Tip metalwork issue?
Regards,
James
Post #619401 Mon Nov 22 2021 10:03am
Tyrefitter
I just cut the tail pipe off,mine was a my15 sdv6.
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #619425 Tue Nov 23 2021 9:54am
911-RRS
Great thanks again.
Did you have a problem with the Exhaust mounting Rubber clashing with the bumper exhaust metalwork?
Regards,
James
Post #619428 Tue Nov 23 2021 10:06am
Tyrefitter
Nothing was catching on mine,you could always bend the bracket so it doesn’t catch. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #619430 Tue Nov 23 2021 10:11am
911-RRS
Thanks Tyrefitter.
It's the 'tube' part of the steelwork that clashes with the exhaust rubber (Image attached)
I'll tin snip a tab out of it.
Thanks again
James
Post #619432 Tue Nov 23 2021 10:37am
911-RRS
Hi again all.
Just to let you all know if you are following this thread that for a 5.0 Car the Exhaust tips on the New Facelift bumper have to be modified so that the 'Cut off' Exhaust (larger Diameter than the 3.0 Diesel) lines up with the tips 'inners'. The Tip metal work has to be manipulated / bashed lower to touch the outer otherwise the exhaust itself will blow between the inner and outer of the tip. Once I manipulated the inner I riveted it to the outer. Images attached.
Also on the 5.0 S/C the Diamond exhaust rubber does class with the Tip Metalwork. The tips cannot be modified / fettled as the the clash is where one of the brackets is welded. I had to fit an after market exhaust rubber.
As the new Bumper has 6 parking sensors (The old bumper has 4) I swapped over the sensor wiring loom and just connected the 4 inner sensors to the old loom. Trouble is the parking sensors are now showing a fault. Does anyone know if the 'Facelift' sensors have a different resistance / set up etc? I may have to strip the bumper and swap over the actual sensors.
Post #619490 Thu Nov 25 2021 3:42pm
