Home > General (L494) > Remote heating |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1741 |
Check the options, there is a facility somewhere to wake it up.
Sat Oct 30 2021 12:11pm |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 390 |
Yes I have seen the wake up feature on the app but you can only set a day when you want the car to wake up so you can use the remote heating. Ok if you know which day you will use the car. I have a van I use as my Dailey driver so sometimes won’t use the Range Rover for 2 or 3 weeks. If I could wake the car up on the day I was going to use it would be good but you can’t wake it up on the same day for some reason, it only gives you the next day onwards as an option. On my last RRS I had a separate fob for the remote heating and was fantastic. Could use it anytime you wanted and never ever failed to work unlike the app operated version where sometimes you press start on the remote heating app then it waits a few minutes until it connects to the car and then sometimes never connects and says there is an error but you don’t realize until you get in the car and it’s cold. Give me the separate fob to work this any day….. |
Sat Oct 30 2021 5:39pm |
Do you actually have the FBH on your car?
Sat Oct 30 2021 5:47pm |
Yes it has the FBH fitted to the car from new. I assume that if I bought the remote by itself it would not work as I assume it would need the receiver unit to work it. When I bought the car 4 years ago I questioned where the remote heating fob was as I knew I had the remote heating fitted. They assured me they don’t come with the newer shape RRS and it’s all done via an app on your phone which it does. |
Sat Oct 30 2021 6:23pm |
teldec Member Since: 29 Dec 2019 Location: essex Posts: 77 |
what year, mine is a 2015 and has a separate remote for the fbh
Mon Nov 01 2021 11:50pm |
Mine is a 2015 reg but 2016 MY. I don’t have the separate fob, I use the Land Rover app on the remote climate bit. Can you use yours on the app too? |
Tue Nov 02 2021 10:37pm |
yes i have the incontrol app etc as well |
Tue Nov 02 2021 11:09pm |
Mmmm that’s interesting, did it come with the car when you purchased it? |
Wed Nov 03 2021 12:16am |
That i could not tell you as i purchased it used but like yours is a 2015 but 2016 build spec, mine is a sdv8 so i think the fbh is standard on those |
Wed Nov 03 2021 8:27am |
Mines the SDV6 so maybe that’s the difference then as I think the FBH is standard on the SDV8. |
Wed Nov 03 2021 9:31pm |
Just looked at my topix spec sheet. It states fuel burning heater and park heating with remote control as separate items. That to me says I should have a separate remote for the park heating. I’ll call the dealers over the next few days and see if they can shed any light on it. |
Wed Nov 03 2021 10:02pm |
TheGoodWillOut Member Since: 18 Oct 2018 Location: TheNorth Posts: 56 |
looks like you're running the old app, is it the same if you install the new app ? |
Thu Nov 04 2021 2:52pm |
Thu Nov 04 2021 10:20pm |
So I thought I’d use the wake up timer on the remote heating tonight and wake the car up tomorrow as I knew I was going to use it then got this on the app. Surely the 4 day thing on the sleep mode of the car can be altered?
Sat Nov 06 2021 12:07am |
