Home > In Car Electronics > M.O.S.T ring break |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
Could be a break in the optical fibre. You can test both ends with a torch.
Tue Jul 20 2021 6:37pm |
grimreaper Member Since: 18 Oct 2020 Location: Cheshire Posts: 18 |
Thanks for your insight Andy K will do the torch test tomorrow, what does changing out the head unit entail if you dont mind enlighteningm me TIA
Tue Jul 20 2021 8:43pm |
don't know sorry.
Tue Jul 20 2021 8:52pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
Easy enough to remove head unit if needed,
Tue Jul 20 2021 11:06pm |
Thanks Col further to my last post the Dab icon and cd soft keys are grayed out the radio button is pressable but does nothing
Wed Jul 21 2021 4:51pm |
further to this problem diagnoses of my car took place today seems that the head unit is caput or needs software update,as the car was in the other month for a sat nav update I have p[lumed for a used head unit which I will have to get recoded through the main st(d)ealer hopefully that will be easy enough because you can now do it online through land rover fvor £20.
Thu Jul 22 2021 3:24pm |
