Home > General (L494) > Slight oil leak from transfer case
kevin reevse Reeves
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Hi ALL,
Does anyone have a weeping transfer case, I seem to have a slight weep, not enough to leave a patch on the drive but moisture when rubbed with your finger. Is this going to be a problem or something you can live with? Anyone else noticed or suffer with this issue.
Post #614756 Mon Jun 14 2021 1:33pm
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
This is the same for me, Im planning to change the oil, so when I drain it I hope there is still some in there......
I wiped it and it I just get dry old oil on my rag but it looks slightly wet.
It doesnt seem to be coming from a shaft seal but maybe the case join.
Post #614757 Mon Jun 14 2021 1:55pm
kevin reevse Reeves
So when you refer to an oil change, your talking about a transmission oil change? Would you do the recommended double flush then replace the oil?
Post #614770 Tue Jun 15 2021 6:37am
Crraigymmmmm
No just the transfer box oil change, my RR has done 75K now so thinking about the gbox oil too but yes probably the double change oposed to a powerflush as I have heard of lots of stories where problems appear after those on units that werent problematic beforehand,
I think power flush is good if you have problems.
Post #614809 Wed Jun 16 2021 10:39am
CarlStuart
Spain 2013 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I have the same issue
I have the same issue, We have had teh case of twice now and even followed teh service buliten and we still have a issue, did you solve yours?
Post #639572 Sun Feb 11 2024 11:58am
