Home > Maintenance & Modifications > How much oil just to take back to full level. |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 576 |
Third of a litre should do it no more |
Sun Mar 28 2021 2:14pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
Its approx 1L between minimum + maximum levels on the display, 125ml(ish) per division |
Sun Mar 28 2021 2:18pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
First point: Believe Disco Mickey he knows what he’s talking about.
Sun Mar 28 2021 3:31pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
Agreed. I wouldn't try to top up on one division. Too easy to overfill it. 2012 SDV6 - it's missing a couple of cylinders
Sun Mar 28 2021 7:57pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1128 |
^ yep, only add oil when the car tells you to, I've seen what happens to a Disco4 with oil overfill and it wasn't pretty nor cheap to fix --
Mon Mar 29 2021 7:31am |
Sparkey Member Since: 03 Feb 2021 Location: Yorkshire Posts: 24 |
Thanks for the replies. |
Mon Mar 29 2021 7:33am |
Mike, is it 1L on all models, or is this specific to the SDV6? I tried but didn't find a reference in the workshop manual. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Mon Mar 29 2021 7:41am |
At what point will the vehicle warn to add oil?
Mon Mar 29 2021 9:38am |
The car doesn't warn you when the oil is low |
Mon Mar 29 2021 11:19am |
Seepee3o Member Since: 05 Dec 2020 Location: Hogsthorpe Posts: 12 |
Mine is on halfway Mark and I was wondering whether to add oil or not. Not happy that it won’t warn me to add so will attempt to add 125ml per division (less 125ml to be safe!) 2010 3.0 TDV6 HSE Luxury - Santorini Black - First RRS and lovin’ it |
Wed Apr 14 2021 8:11pm |
At halfway, I would add oil, but do it in 125ml increments and check after each addition.
Wed Nov 17 2021 5:03pm |
