Home > Maintenance & Modifications > Help! Loud tapping noise following timing belt change |
33daz4ba4 Member Since: 21 Jan 2021 Location: Windsor Posts: 2 |
Hi All,
Tue Jan 26 2021 11:45pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
Does not sound good> maybe the garage made a mistake and they did not install the cambelt properly. The engine might be out of timing...which could cause severe damage. Do not run it! Have it towed RRS 3.0 SDV6 HSE Lux
Wed Jan 27 2021 4:26pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Oh, let us know how you get on. 2006 2.7 TDV6 HSE in Cairns Blue. |
Wed Jan 27 2021 6:29pm |
Ok, so took back to G-Salmon and it was the fan knocking on the housing - the fan blade is slightly cracked and has wobble, they said they must of done something when removing to do the belts!
Wed Feb 03 2021 10:48pm |
