Home > General > Engine dies on full throttle. |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 |
Any warning messages on dash when this happened? |
Sun Jun 21 2020 7:27pm |
dashingdave Member Since: 20 Sep 2014 Location: Dogtown Posts: 29 |
nothing but think it's been building up to it now look back. Carbon clean tomorrow so hope that will help and I'll have it diagnosed. one things for sure can't drive it like this. If you need the grunt it has to be there. Actually I'll check the dash when I boot it next time. |
Sun Jun 21 2020 8:12pm |
Had the same 2 weeks ago my on TDV8 but it was simply one of the top inter cooler hoses with a split in it. worth checking that out just in case. |
Sun Jun 21 2020 10:18pm |
good idea thanks, my old V8 had the split until I changed for better pipes. D |
Mon Jun 22 2020 12:31pm |
So, the remap took a couple of hours and the graph printout was interesting to compare before and after.
Thu Jun 25 2020 10:16pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
Who did the remap? 2012 SDV6 - it's missing a couple of cylinders
Fri Jun 26 2020 7:36am |
Celtic Tuning in Newquay Cornwall. Think they may have the only 4WD rolling road in the west country. |
Fri Jun 26 2020 11:00am |
Snap. Just the same for me recently. No warning lights but message on the display saying Engine System Fault. And severe limp mode until the hoses were changed. For a few weeks before it went pear-shaped I was noticed a strange quiet groan from the engine under gentle load which I guess was air leaking through the split. Running your had around the pipe will soon show you if there's a split as it'll be quite mucky. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Sat Jun 27 2020 3:06pm |
When my old TDV8 split an intercooler hose, there was no warning message, just some noticeable smoke as it over fuelled. I guess there's a threshold value for the error message. 2012 SDV6 - it's missing a couple of cylinders
Sat Jun 27 2020 7:55pm |
