Home > Maintenance & Modifications > RAC Trackstar Plus System |
d3matt Member Since: 12 Jul 2005 Location: Oxfordshire, UK Posts: 730 |
They are there to use two additional subscriptions options you can have - emergency calls & safespeed.
Thu Oct 27 2005 10:30am |
A shot in the dark, but does this system come with the function that allows the control centre to speak to you? e.g. you have a crash and the system immediately contacts the control centre and puts you in touch "hands free"? I think the BMW Assist feature can include that... although not sure how it works from a technical perspective.
Thu Oct 27 2005 10:31am |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2569 |
Thanks Mpwox11,
Thu Oct 27 2005 1:04pm |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
Always use somebody reputable. Nothing worse than a poor install and rattles later in the life of the car. I always use the same man who supplies our two communication systems and he knows if it is not done correct he will lose our custom and lots of money. He always hates working on my cars because he knows I watch every move he makes. Its out there somewhere. Second V10 Treg on the drive at the moment. |
Thu Oct 27 2005 1:31pm |
I'm not sure how easy it is to get inside the RRS. I haven't really looked too hard on mine. I felft the same, that is why I changed insurance companies to one that didn't want a tracker fitted as I didn't fancy pulling the car apart. I'd also rather pay slightly more on the insurance as this is still less than the annual tracker subscription fees. Anyway, not fitting the speaker or mic does help a lot as the rest of the fitting would probably done from below the dash and hopefully would not involve removing too much. I'm not going to say where the box might get fitted for security reasons. Fitting the antennas is normally tricky as these need to go as high up as possible and as close to the lower centre of the windscreen as possible so they get good access to the sky. Sometimes you can fit these behind the speedo dials. However, as the windscreen is heat protected and has heating wires, this would seriously hamper the signals, so it would be better to fit the antennas externally - maybe in the wiper housing between the bonnet and the windscreen, or maybe share the LR roof antenna (if this is possible - not sure). Also the guy will need to find the wiring to the fuel pump which can be tricky. This is why I pay others to fit these, as fitting a TrackStar is very awkward. Fitting a SmartNav is easier, but then trim on modern cars is getting very difficult to remove. Who is fitting this for you? Matt ------------------------------------------- RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance! |
Thu Oct 27 2005 2:18pm |
Company in question I bought the unit from and who are arranging the fitment are called Driven In Car.
Thu Oct 27 2005 4:22pm |
RRUK,
Thu Oct 27 2005 7:02pm |
Thanks for that, I shall enquire L319 D4 HSE
Fri Oct 28 2005 9:09am |
I spoke to DrivenInCar, they have put my mind at rest. They use a company called TSN Automotive for the installations, he said they have done well over 20 Range Rover Sports and many Range Rovers and the guy who does my patch has done a large proportion of those. He said that the Sport is actually one of the easier cars to fit to, compared to Mercedes which are difficult. I guess you could read that as the Sport falls to bits easily!
Fri Oct 28 2005 2:24pm |
If by Mercedes, they mean the ML, then I'd agree. That was the last car I did (my own) and it was a pig to fit. Hence why I pay others to do it now. Matt
Fri Oct 28 2005 3:41pm |
RAD Member Since: 23 Sep 2005 Location: In the chippy! Posts: 309 |
I've got the RAC Trackstar fitted in mine.....which did cause the removal of the GPS display, but no rattles.
Fri Oct 28 2005 4:19pm |
RAD,
Fri Oct 28 2005 5:41pm |
To be honest.......it was done at the dealers prior to delivery, although with the exception of an earth wire, you wouldn't know it was there.
Sat Oct 29 2005 6:09pm |
