Home > Maintenance & Modifications > Tdv6 2.7 inlet manifolds replacement |
Fluff006 Member Since: 03 Nov 2019 Location: Dorset Posts: 14 |
What £70 ish from land rover or eBay? It’s the stupid clips that put me off too. In my experience if you can leave those types of clips alone then do. You talk like you’ve experienced a leaky pipe? It’s only a shave of the corner of the leak off nipple that’s missing but the drip is from the pipe inlet. All pipes are tight and if I hold the leak off in a certain place it will slow the drip down. If you see a link please send it. I’ve looked everywhere. Thanks. |
Sun Jan 12 2020 11:20pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
https://rover.ebay.com/rover/0/0/0?mpre=ht...2762802446
Sun Jan 12 2020 11:24pm |
yes I had a similar problem where the end broke off and I had to replace it, to prevent leaking |
Mon Jan 13 2020 1:16pm |
So drove it for the first time today. About 50 meters and felt like it put the front passenger side brake on. Then said edc fault. Special functions not available. And lowered the suspension. Only when I drive it. On start up it’s fine. |
Sat Jan 18 2020 7:35pm |
