Home > Maintenance & Modifications > Supercharged re-map
exint2
Supercharged re-map
Sorry if this has been posted before, but which companies aside from Paramount offer an ECU Re-map for the S/c - and does anyone have any practical experience of them
Thanks
Post #86703 Fri Feb 23 2007 1:49pm
Worth speaking to both JE and Turbochip, both of which are forum sponsors. I don't believe SC performance upgrades are done at the ECU like the diesel engines. I believe their route is via upgrades to the charger itself (and exhaust changes).
Post #86704 Fri Feb 23 2007 2:00pm
LRtuning
2006 Range Rover Sport Supercharged Cairns Blue
The Supercharger uses a DENSO ecu which can be re-mapped Smile Chips with everything
Post #86778 Fri Feb 23 2007 5:34pm
thebishman
United States 2006 Range Rover Sport Supercharged Bonatti Grey
Most upgrades to the Jag 4.2 litre S/C engine have come from a combination of an 'under-drive' pulley as well as an ECU re-flash I think. Gains approximately 50hp. An exhaust upgrade might return an additional 10-20 hp, but I can't verify that.
Bish '06 RRS S/C Bonatti Grey/Ebony/Cherry with RSE; PTI; Electronic Rear Diff and Sirius Sat Radio.
Post #86790 Fri Feb 23 2007 7:51pm
LRtuning
'Bishman,
Trouble with pulley upgrades is that they involve a major mecanical modification to your vehicle for relatively small bhp gains.....an expensive option and warranty 'out of the window' Sad Chips with everything
Post #86791 Fri Feb 23 2007 8:41pm
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
Is the standard ECU so far out there are useful gains without getting any more air into the engine??? Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #86794 Fri Feb 23 2007 9:49pm
LRtuning
Simon,
The standard ecu has lots of additional power that can be 'released' but the majority of tuners have no idea how to identify the engine map areas within the DENSO system.
There is a great deal that can be done with air/fuel ratio, torque limiters and throttle sensitivity.
There is also an 'overboost' protection in the maps which is why many people can only increase boost pressure by 0.1 bar (or a small pully change in lay man terms).
If you combine a pully change, exhaust and complete remap as above I see no reason why you could not release at least 80bhp....
Post #86826 Sat Feb 24 2007 8:46am
any side effects?
Post #86836 Sat Feb 24 2007 10:14am
thebishman
LRtuning wrote:
'Bishman,
In your response to my post you seem to disparage a pulley exchange, but then two posts below you tell Simon that a pully, (sic), change, exhaust and ECU re-map could get about 80 bhp. So what exactly ARE your thoughts on a pulley exchange; yes or no?
Further, pulley exchanges are not a major mechanical problem, normally taking less than 2 hours of labour, plus most, (all?), dealers would have a hell of a time noticing that the supercharger pulley had been switched out. Supercharged engines are not as easy to 'tune' as turbocharged engines are, and the most reliable way to derive a meaningful increase in bhp is to exchange the supercharger pulley, and then re-map the ECU to take advantage of the increased rotational speed of the supercharger. Add to that a freer flowing exhaust, (IF one exists for the RRS S/C), and once might get approximately a 50-70 bhp reliable increase as I originally stated.
Post #86870 Sat Feb 24 2007 4:00pm
LRtuning
Bish,
I wasnt dismissing a pulley change but the engine management should always be 'tackled' first before resorting to mechanical modifications Smile
So in a perfect world....ecu remap as 'Stage 1' tuning and Pulley, exhaust and remap as 'Stage 2' Smile
As for side effects; same as could be expected with any diagnostic remap (diesel or petrol) that if LR foind out about it they could restrict your warranty....highly unlikely....but still a possibility Chips with everything
Post #86875 Sat Feb 24 2007 6:00pm
Just a general comment, however in my understanding I dont believe any tuning company (except the big boys such as AMG etc) or expert in this field actually completes full NVH tests for the modified cars - LandRover have to ensure the homologation of the RRS etc and hence I expect edge of the side of caution when it comes to the engine tuning/performance - if they can get more performance and better mpg and still maintain the expected lifetime of the vehicle, then they would do it.
Modifying the engine must have some effect on something (be it durability, emissions at lower temps etc) - unless the NVH testing has been completed to prove otherwise of course
Just my thoughts
Post #86879 Sat Feb 24 2007 6:21pm
aljo
Just my thoughts
good point kaine Thumbs Up
Post #86881 Sat Feb 24 2007 6:29pm
LRtuning
Kaine,
I agree but consumers want to have their cars remapped and while they do there will always been tuners in business.
As long as their development process is robust then cutsomers will be satisfied that they have a quality product Chips with everything
Post #86883 Sat Feb 24 2007 6:30pm
aljo
LRtuning wrote:
Kaine,
good relpy LRtuning Thumbs Up
im still undecided as to have mine chipped as yet Rolling Eyes
Post #86891 Sat Feb 24 2007 6:45pm
LRtuning wrote:
Kaine,
yes they do - quite right - so I take it that my comments are part of a disclaimer with a performance upgrade?
Post #86909 Sat Feb 24 2007 7:25pm
