Home > Technical > Sunroof behaviour
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Sunroof behaviour
Just wondering if anyone else have the same problem:
when I close the sunroff, it close and once it reach the "close postion" it reopen again and then try to close again before reopen.....Does that maybe 50% of the time. The only solution I found is to quickly press the tilt position once it is close and then reclose it... Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #86698 Fri Feb 23 2007 2:18pm
Don't have a sunroof on the RRS but had the same problem with 3 BMW's i had X5,740i and B10 RRS TDV6 Gone but still around
Post #86709 Fri Feb 23 2007 3:33pm
I've had that problem on a BMW too - it was a faulty anti-foul sensor on that, replaced it and all ok. I didn't have a sunroof on my RRS either so not sure if it has them.... ? Confused
Post #86712 Fri Feb 23 2007 3:47pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
I opened and closed the sunroof for the first time last night, just to see if it worked.
I think one of my cars used to do this - there may be a safety device which opens the roof if on closing it encounters resistance, like the windows do. Perhaps the track needs lubrication or cleaning?
Post #86713 Fri Feb 23 2007 3:51pm
That sounds about right S a faulty sensor or maybe need lubrication like Philmw said! RRS TDV6 Gone but still around
Post #86717 Fri Feb 23 2007 4:08pm
aam1234
2007 Range Rover Sport Supercharged Rimini Red
Don't lubricate it, it will gather dust.
Post #86719 Fri Feb 23 2007 4:12pm
I hope not think i'll use it a bit to often for it to gather any dust Laughing Laughing Laughing Wink RRS TDV6 Gone but still around
Post #86723 Fri Feb 23 2007 4:19pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Jimmy next time you are in your motor, open your sunroof and keep your finger on the button for two or three seconds after the glass is fully open. Then do the same to close, keep your finger on the button once the glass is fully closed.
By doing this you will reset the sunroof. Like the one touch windows it can "loose it's memory" if the power supply is disconnected whilst open.
The reason the glass 'bounces back' on closure is normally down to this failure mode. If it continues after you have tried resetting then it could be a faulty anti trap sensor as shmoogle mentioned. But resetting normally does the trick. Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #86761 Fri Feb 23 2007 5:17pm
Thumbs Up Thumbs Up Thumbs Up
Post #86765 Fri Feb 23 2007 5:27pm
Top tip TB Thumbs Up
May be we should start a new tread all with tip's for your RRS or have we already started one?? RRS TDV6 Gone but still around
Post #86767 Fri Feb 23 2007 5:41pm
aam1234
Thanks TB Thumbs Up
And I thought this forum is only about boobs Laughing
Post #86771 Fri Feb 23 2007 5:49pm
aam1234
That's an excellent idea, Jay. Why don't you start a new thread about tips, mate.
Post #86772 Fri Feb 23 2007 5:51pm
I'll do mate don't ive just a a couple of beers so I'm a bit Very Happy RRS TDV6 Gone but still around
Post #86787 Fri Feb 23 2007 8:29pm
Jimmy_75000
Thanks for your help guys! The reset tip has fixed it! How can we live without this forum!!! Cheers! Thumbs Up Range Rover Vogue ‘17 TDV6
Post #87057 Sun Feb 25 2007 6:57pm
TB
to all of my fans out there in RRSport land.
I will be signing autographs later. Cool Cool Cool Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #87068 Sun Feb 25 2007 7:25pm
