Home > General > LED Wing Mirrors Retro fit |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
It's a long time ago I did mine but I'm sure it is the yellow wire on one side and green on the other but can't remember which is o/s and which is n/s, do have a spare pair of mirrors here so could have a look if you get stuck.
Fri Jan 10 2020 10:00pm |
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 |
with regards to cable.
Fri Jan 10 2020 10:40pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
It’s Pin 12 you need, that should be a vacant slot in your connector. On a MY14 Disco this was a Green and White wire of 0.5mm diameter. It’s earthed through the common mirror ground pin 6. So all you need to do is run a wire from the pos wire on your existing door indicator.
Sat Jan 11 2020 8:21pm |
Yeah, this is what I did to mine, as Chris says got a couple of these A/B badges of fleabay and bonded them to the original repeater lamp plastic backing leaving original bulbholders in place, they then cliped in the hole same as original lamps did, did seal around edges though with silicone selant just to make sure they were watertight, being the 5.0L didn't want to use the SDV6 badges. Will have to have a look at the Disco 4 down here as a lot of them have the 5.0 engine in them I believe.
Sat Jan 11 2020 10:07pm |
Thanks guys.
Sat Jan 11 2020 10:13pm |
Personally thought it defeated the object of fitting mirrors with led indicators in them slightly if left in place.
Sat Jan 11 2020 10:17pm |
Ok great. So it’s not something I need to do then.
Sat Jan 11 2020 10:33pm |
I am going to need to try and pick up a pin connector so that I can put it in to connection 12. Any ideas on a product name , type , size of the pin.
Sun Jan 12 2020 9:23pm |
Are you sure that's the end you want and not this one?
Sun Jan 12 2020 10:01pm |
Thanks mate. Not sure why I didn’t think of buying the complete door harness. Even cheaper and can always salvage for parts in the future if needs be.
Sun Jan 12 2020 10:53pm |
And let there be light!
Fri Jan 17 2020 4:18pm |
Fri Jan 17 2020 10:18pm |
