Home > Maintenance & Modifications > Failed wheel-bearing... |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
That’s proper FUBAR’d 2012 5.0 SC AB
Sat Sep 21 2019 8:07pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
You don't want to be wearing those shoes when it's raining They aren't going to be much use to you when you move to Wales
Sat Sep 21 2019 8:23pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
It went through is MoT a couple of weeks ago without comment. The "woomp, woomp, woomp" noise was the first sign that I noticed. I'd had some weird noises recently (and before the MoT) that were eliminated with a change of power-steering fluid.
Mon Sep 23 2019 8:03am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Had an advisory for a wheel bearing on mine last month - so far I can't hear the tell-tale whomp, but do hear the occasional 'whirrr' that goes away if you unload one side of the suspension.. doesn't look like a terrible job; undo hub nut, undo four bolts, refitting is the reverse of removal? Of course, I base that purely on looking at the part itself..
Mon Sep 23 2019 8:22am |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 387 |
easy enough forthe front, but getting the old ones off requires a bit of brut force.... I ended up using a full on sledge hammer to knock the old hub out... the neighbours looked very worried when was swinging it at the car |
Mon Sep 23 2019 12:46pm |
Mon Sep 23 2019 1:59pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 750 |
Have a look here; https://disco3.co.uk/forum/topic116658.html |
Mon Sep 23 2019 4:45pm |
Thanks! That actually looks quite simple.. he says, clearly cursing himself to suffer several snapped bolts and a broken wheel speed sensor 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Tue Sep 24 2019 8:08am |
I'm not saying I would do it myself.... |
Tue Sep 24 2019 8:09am |
Though not on a LR, when having problems in separating chunky bits of metal, I have spurned the sledge-hammer in favour of a blunt bit in an SDS drill in 'hammer' mode. Tapping all round broke the bond due to corrosion. |
Wed Sep 25 2019 4:59pm |
Handy tip! 2012 5.0 SC AB
Wed Sep 25 2019 6:17pm |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 |
My front wheel bearing was going on my 2011 Sport.
Wed Sep 25 2019 10:21pm |
I'd probably lop the end off an air chisel bit and use the air chisel, but .. same idea - good tip indeed Mind, I have a range of legged pullers if I do decide to do it myself; just nothing to "suck" the stub back into the hub (the second half of the LR SST).. probably a good shove and using the hub nut will do; that's certainly worked before for me on other cars
Including pads that's really not bad at all .. if I'm feeling lazy I'll give New Duston Garage a call and see what they quote .. ah, heck, let's do it now .. £276.48 excl brake pads, less if it only takes them an hour. Not bad at all. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Thu Sep 26 2019 10:38am |
It cost me £305 inc VAT, for an OEM bearing, clearing all faults and a road-test. Having it collected and dropped-off made the whole thing painless. It would have cost me that in lost time to do it myself and my neighbours were spared all the swearing.
Thu Sep 26 2019 9:44pm |
