Home > General > 5.0 SC speed limiter |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
I’ve read that the RRS 1 had an electronic limiter set at 125 MPH or 200KMH so 250KMH is way over that. 2012 5.0 SC AB
Tue Jul 02 2019 9:07am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
Yes, I think it's electronicly set at 140 mph about 225 Kph from the factory, not sure how he recorded 250 kph my speedo only shows up to 230 kph. RRS2 may be different although I belive it can be disabled with diag. equipment on the RRS1. I have had mine reading 139 mph via gps.
Hamtheman Member Since: 18 Jan 2017 Location: Joburg Posts: 33 |
My "friend" agrees that the analogue speedo shows up to 230 KPH, but the digital display keeps going, I was expecting a limiter to kick in , but nothing. |
Tue Jul 02 2019 9:24am |
Never thought about looking at the dgital read out, more concerned with looking out the windscreen Sounds like it's been disabled.
Tue Jul 02 2019 9:33am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1128 |
Ham, what year model does your 'friend' own?
on a Spec Sheet for the UK spec, the top speed is listed as: 140 (155 opt) mph, not sure what the opt mean? http://www.rrsport.co.uk/gallery/albums/us...260313.pdf -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Tue Jul 02 2019 9:40am |
Naks, its a late 2011, its not an issue, I just assumed there would be one, like I said it hit 250 with no prob and was still pulling hard. (IIRC around 5000 RPM)
Tue Jul 02 2019 12:19pm |
Perhaps 155mph opt is ‘optional’. I.e. to have it removed. 2012 5.0 SC AB
Tue Jul 02 2019 3:04pm |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 237 |
Looking at this the friend I assume is in South Africa? On this basis LR may have supplied vehicles without ay limiter as H&S etc in not a consideration there. Also it aids escaping a car-jacking.... MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
Tue Jul 02 2019 6:13pm |
