Home > Technical > Rear Load Cover - How to tell the difference ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4867 |
Easiest way to tell difference, first picture split tailgate, second picure one piece tailgate.
Mon May 13 2019 1:05pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
Im pretty sure mine is the 2nd one . Are there any inserts that are meant to be on the car trim pieces to make it fit snug ?
Mon May 13 2019 1:07pm |
Tue May 14 2019 6:02am |
The length of my cover is 1350mm then the locking lugs stick out about another 10mm each end of cover.
Tue May 14 2019 8:11am |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 180 |
Not sure if these help.
Tue May 14 2019 8:18am |
Thank you both for the pics , on the underside of mine (Right) there is a little black tab . Is that meant to sit on/within the cars trim panel or on the outside ? |
Tue May 14 2019 8:21am |
The black tab is spring loaded and I think somehow lock the cover in place, it does actualy sit in the trim panel so the weight of the cover pushes down on it.
Tue May 14 2019 8:33am |
Does this look short to you Col ?
Tue May 14 2019 8:36am |
Yes it does, have you measured the length of the cover? perhaps the issue is with the trim panel somehow.
Tue May 14 2019 8:40am |
At work atm , but will measure when i get something out of my boot and compare with yours . Many thanks ! |
Tue May 14 2019 8:41am |
It does only just locates in the panel but it has never fell out yet. Which end are you locating first?
Tue May 14 2019 8:50am |
tried both ways , just doesn't seem to fit snug ! |
Tue May 14 2019 9:48am |
Ok had a play , size was the same as stated by you. Managed to shift it a bit to the right and it does seem to fit better now . Its not 100% snug , but judging by your pics looks like it now fits the same as yours |
Tue May 14 2019 11:05am |
Yeah, couldn't be described as a perfect fit.
Tue May 14 2019 11:15am |
