Home > Technical > Had to happen I suppose |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
Tue Feb 13 2007 1:05pm |
"I'm afraid we couldn't replicate the reported fault, Mr Josh"...
Tue Feb 13 2007 1:45pm |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 |
Bad luck Josh, just a thought, have you tried putting the suspension into high and then low then back to normal, it might just be a lazy sensor some of my Previous cars
Tue Feb 13 2007 5:33pm |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
Business as usual at Land Rover then??? |
Tue Feb 13 2007 5:44pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1667 |
Good idea. Watch the 4x4 display when you do this. Faulty sensors often show up as the wheel bouncing off the red end-stops when you try this. They sometimes do it when you reverse hard, put it in drive and then accelerate forward. I've had two faulty sensors, and both exhibited this behaviour. |
Tue Feb 13 2007 7:54pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Philmw did you have them replaced in the end or were they ok after you did this
Tue Feb 13 2007 8:05pm |
Replaced under warranty (went within the 1st month, probably a faulty batch). N/S/R went first. Replaced. Week later N/S/F went. Replaced. |
Wed Feb 14 2007 9:37am |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Hasn't done it since....no surprise. Still I'm sure garage can make some money out of the warranty TDV6 - gone
Wed Feb 14 2007 8:25pm |
Been in. Plugged it in car won't communicate with them or their machine So now its going in for 2 days
Fri Feb 16 2007 9:17am |
Is this where they plug the testbook in and all the car says is:
Fri Feb 16 2007 9:23am |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
Sorry Josh, can't help with route cause. But I do have a few reservations.
Fri Feb 16 2007 6:40pm |
Fri Feb 16 2007 7:23pm |
Hm..m food for thought there TB.
Fri Feb 16 2007 8:29pm |
bluebarchetta Member Since: 18 Feb 2007 Location: Aylesbury Posts: 10 |
My Disco 3 is in at Hartwells (Cumnor nr Oxford) at the moment with a similar problem
Sun Feb 18 2007 7:08am |
