Home > Technical > Codes read - advice please |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
It could be worth taking the injectors to be tested and replace any as necessary Steve. 3 out of the 6 of mine were out of spec and I think this probably contributed towards me needing to have an engine rebuild. Personally, I wouldn't drive it if it sounds lumpy, but I am no expert. Kev
Wed Apr 10 2019 4:58pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
The stepper actuator codes are because the battery isn't fully charged (prob because the car doesn't get used alot) |
Wed Apr 10 2019 6:17pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1231 |
Thanks both of you. I did research after posting and battery seems to be the culprit by others experience. The car gets used every day but for the last 2 weeks my wife has taken it only doing some 8 miles per day.
Thu Apr 11 2019 5:39am |
I plugged the IID tool in for today’s cold start and 32 mile run to work. Initial start was smooth with no lumpyness at all and the idling figures for all 6 injectors were 983. Focusing on injector #1 off throttle it’s idle readings whilst on the move were 1344, 1358 twice, then from 820 seconds onwards 1276, 1295, 1305 then float around the 12**mark until journeys end. By contrast the other 5 injectors on throttle were all showing 983 and off throttle were around the 900 range.
Thu Apr 11 2019 7:51am |
