Home > Technical > Switched 12v inside the Upper Rear Tailgate |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Does anyone know if there is switched 12v (switches on and off with the ignition) inside the upper rear RRS tailgate.
Fri Apr 05 2019 3:37am |
Any ideas? 07MY RRS TDV6
Sun Apr 07 2019 4:47am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
Maybe way out but isn't the rear demister switched? |
Sun Apr 07 2019 8:37am |
So you are suggesting that when the ignition is switched on power goes to the demister and the demister switch controls that switched power back to earth so completing the circuit? if so that will work
Sun Apr 07 2019 9:53am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
Doubt the window works like that.
Sun Apr 07 2019 10:50am |
